Question about Samsung Refrigerators
My samsung fridge (model SRS535NW ) is not working since this morning, both the freezer and the cooler compartments. In the past few days, I can hear some noise from the fridge. According to user manual, I then checked there are spaces behind the fridge.
2 Suggested Answers
SOURCE: samsung fridge model srs535nw service manual
Behind the white plastic section at the back of your freezer (4-6 screws to remove) there is a drain hole at the bottom. This will be frozen and prevent water from defrost from draining away - we have exactly the same problem. defrost the freezer and ensure this drain is no -longer frozen. I used hairdryer and warm water to clear. You may have a secondary problem of defrost cycle going wrong - the most common replaced part is R1098 or something like that a defrost sensor which is easy to replace by removing the top rear plastic section - 3-4 screws to remove and it simply pulls out as it is lightly clipped in. I was worried about breaking it but it came out with a bit of a tug. The defrost heating element is another part which can pack in. I'd replace the other part first and see how it goes.
Posted on Nov 11, 2009
Samsung freezes but not cooling
You need to post the model of the fridge for precise answers. In general, all refrigerators work by making the freezer section very cold and then opening/closing vent doors to blow some of that cold into the fridge compartment. There is a thermostat in the fridge section that opens the vent door when things need to be cooler, closes the door when cool enough. Look for that door and see that it works and make sure the blower is running and door vent not blocked (or frozen shut).
Feb 11, 2015 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Hello, we hv the samsung SR-C31NMO samsung fridge. from 2 days the freezer is not working. Same thing had happened few days back, but automatically it became normal. I can hear some sound behind the...
It sounds like the evaporator fan is not working properly. If the fan is stopping and starting it can cause the freezer to become a block of ice.
The fan motor may need replacing
Mar 31, 2011 | Samsung Refrigerators
Samsung fridge model srs535nw service manual
Oct 06, 2009 | Samsung Refrigerators
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
