Question about Panasonic TU-PT700U DTV Receiver
Panasonic TU-PT700U DTV Receiver - When switched on the Blue light comes on and within 5 seconds it starts blinking and turns off. It also turns off the TV in stand by mode. Any solutions?
5 blinks on a TU-PT700U panasonic plasma tv means what?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 18, 2016 | Panasonic TU-PT700U DTV Receiver
Turn it on blue light comes on after a few seconds the red light starts flashing then the device switches off
Sounds like the battery is not charged, or they are not properly Paired to there wireless receiver.
Hold the power button for 5 seconds and most of them will enter pairing mode, then on the receiver use a paper clip and insert it into the small hole in it to get the receiver into pairing mode as well. Refer to the supplied instructions it came with if that does not work.
Nov 28, 2015 | Radio Communications
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
Panasonic 50 Onyx broken
Did you look here:
http://www.twoguysny.com/products/Panasonic/pan/tupt700u.html
Mar 13, 2012 | Panasonic Televison & Video
Only green light on
shanonl,
If the lights will not turn on, try unplugging the receiver from the electrical outlet for about 10 seconds. Plug the receiver back in, which will make the receiver reboot and re-acquire satellite signal. If the receiver does not turn back on, at least the green and amber lights on, we may need to replace the receiver.
Ray Calo
DISH Network
May 15, 2010 | DISH Network DVR-625 DTV Receiver /...
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
I have a panasonic onyx 42 xvs30 plasma. Will not turn on. Moved from my sons home. Is there a card that is supposed to be in the media box? Blue light turns on for 2 seconds and then goes off quickly. It...
hello, make sure your ac power is correct as far as gounding and proper polarity.
some homes are wired incorrectly and the tv wont operate like this.
first step is to check your sockets with a (ground fault tester) its a small plug in unit with led lights that indicates if there any electrical fualt in your power lines.
if it isnt your wall sockets then it is inside your tv set. the media slot is for a media card it shouldnt have anything to do with your tv working or turning on.
if your not able to see a welcome screen menu when you turn it on, this indicates a shut down circut or power issue.
you may want to find a tv service center to check it for you
this is your best chioce.
hope this helps
Dec 22, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
My Panasonic TU-PT700U Digital media Receiver shuts the TV down after 10-30 minutes and the blue light flashes 5 times repeatedly. I have to unplug the unit and let it cool for several hours before it it...
Hi, I have a spare TU-PT700U that may be of use for you to solve your problem without having to replace your system.  My Panasonic onyx series monitor was stolen out of my house, but they left behind the TU-PT700U and cable.   If interested, respond to my craigslist post..
http://sfbay.craigslist.org/sby/ele/930283631.html
Nov 11, 2008 | Panasonic Televison & Video
Panasonic TU-PT700U DTV Receiver Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
