Question about Hitachi 60UX54B/55K 60" Rear Projection Television
I have a 60ux55k rear projection TV, and like other posts, it just "died". The power light comes on, but no picture or sound. I unplugged it as suggested, but still nothing. All the LED's on the board light green, except one which is red. Without an actual schematic, I am guessing it might be the surge protection circuit and has remained "stuck". Is there a non-expensive solution? Is there a way to obtain a better manual than what was supplied when purchased? Are there any detailed schematics available?
  • 308 Answers
SOURCE: Hitachi 50ux58b
It's possible that the Convergence IC's are causing a shutdown of the power supply. Also on this model, there have been problems with: C707 - 1000pf @ 2kv Cermaic Disc Cap (normally a small blue one) Hitachi Part # 0244211. I901 - A STRM6811a Reg Ic and E994 - 2.0 Amp Circuit Protector (Pico Fuse) having a high failure rate. If the 2 amp pico fuse was good, and the capacitor looked OK, then I would check the convergence circuit board. There are many other parts that can also cause shutdown problems, however.
Posted on Jan 03, 2007
techman
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
  • 1694 Answers
SOURCE: Hitachi 60sbx78b Won't Turn ON...need advise
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Posted on Jan 29, 2008
  • 927 Answers
SOURCE: DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Posted on Sep 01, 2008
SD Tech
  • 14553 Answers
SOURCE: Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Posted on Aug 07, 2009
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
We have a rca 32v434tyx tv. The power light comes one but no picture or sound. What is the problem?
ower will come on to front panel. No buttons will work. No picture or sound. Have to unplug for red power on light to go OFF
Date: November 2006
Model # 32V434TYX
Serial # CB128G444CF001
Jun 26, 2010 | RCA P52926 52" Rear Projection Television
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Jcv rear projection tv modal# hd-61fn97
no picture and no sound blue and red light flashing continually cannot turn off unless we unplug it.
Oct 13, 2008 | JVC HD-61FH96 61" Rear Projection HDTV
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Losing Picture
It sounds like the tv is dieing but since it is rear projection you may be able to fix the problem by replacing the bulb in the tv
Jun 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
