Question about Compaq Presario CQ60-212US Notebook
Hello, I have a Compaq CQ60 and have problems with the LCD display, which works intermittently. I had the entire LCD replaced about 4.5 months ago. Worked great until a couple weeks ago, the LCD went black again, no dim picture, just black. The laptop itself works fine, and I can view display via external monitor. The LCD came back on about a week ago, then again this evening. Could it be something with the internal display switch? I do not see any such switch externally, as I thought it might be getting stuck. Or perhaps a cable of some sort. Please advise, I would like to try to fix myself, as don't want to put more $$$ into this machine. Machine itself is GREAT. Just not currently functioning as a "laptop". Thank you.
  • Compaq Master
  • 2,472 Answers
Is this a CCFL LDC
if yes the inverter is bad. (a card tiny, and thin)
its old LT.
the books are gone now.
the service book tells you how to replace the CCFL inverter
find a used good one is problematc.
why not buy a newer LT
or just run the external screen and be happy
I guess you have not read the user guide yet?
about the VGA hot key.
mine has.:
1: external only
2: internal only
3 both
4: auto. (i think only my newer HP has this)
mine is Fn+f4, but on a relic compaq, gee buy the book,
or google search for it for weeks,
next time post to HP< there is no COMPAQ for years.
hp owns it. totally
ever seen this before. the fail like LT batteries do. often.
http://www.ebay.com/itm/New-15-6-Laptop-Screen-LCD-Inverter-for-Hp-Compaq-G60-G50-CQ50-CQ60-Series-/251312052451?hash=item3a835d98e3:g:ARYAAOSwal5YJoxR
search there "compaq CQ60 inverter"
bingo.
when the sceen is dead do this.
see the flash light here, BINGO? bingo for inverter *****?
http://pcdied.com/black-screen.html#Dimbulbs
Posted on Jun 27, 2017
SOURCE: display problem
i have display problem some time show but some time not display
Posted on Jun 04, 2008
DCSE
  • 191 Answers
SOURCE: LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Posted on Jun 07, 2008
  • 13433 Answers
SOURCE: My compaq presario x-1000 hard drive light and dvd rom light flashes. Won't boot up.
Try disconnecting the harddrive from the case and then place it back in. if that doesn't help you may have a faulty drive, hows warranty? Compaq / HP would fix it for you free if you still have warranty.
let me know.
Thanks,
Ekse
Posted on Oct 31, 2008
gsage
  • 180 Answers
SOURCE: monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Posted on Mar 08, 2009
  • 108 Answers
SOURCE: Hello. I received a Compaq Presario 1620, needed
There are a few things that come to mind:
  1. Turn off the laptop and leave it off for 5 minutes- then restart it (with the external monitor unplugged). Check to see if you have your video back.
  2. Unplug the monitor, then hit the hotkeys again to switch back and forth between inputs- does the video show up?
  3. There could be a loose wiring/connection issue between screen and the rest of the laptop. Sometimes fiddling around with opening and closing the lid will work. Otherwise, you may need to open the laptop to check the connection between the two (not recommended if you are not good with fiddling around inside computers), or taking it to a tech who can do it for you.
Hope these answers help.
Posted on Dec 17, 2010
WHAT IS THE SOLUTION TO MY BLANK LCD FOR COMPAQ
Replace the LCD.
1. Buy the LCD replacement on eBay.com,
2. Buy small screw driver set at local hardware store,
3. Download Compaq/HP Service Manual from HP website and read it,
4. Do DIY screen replacement.
Mar 03, 2014 | Compaq Presario CQ60-220US PC Laptop
Hi, I have a laptop compaq presario cq 60 .When I switch on the computer the fan start working but the screen is black doesn't start .What could be the problem? Thank you
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jul 17, 2011 | Compaq Presario CQ60-212US Notebook
I have presario CQ60 211ed power on but no display and not laoding
Hi cris rubis87,
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
Hope this helps.
Jun 09, 2011 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ60-215DX. Doesn't start
You will need to buy a new battery, there is no way old one will be OK. To see if it works, remove battery, and use wall adapter ONLY, PC should work fine. If not maybe Flat CMOS, replace, If replace and still NO go.must be bad motherboard (maybe try charge battery 5 hours left alone)
Mar 27, 2010 | Compaq CQ60-215DX Notebook
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
Laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Jan 04, 2010 | Compaq Presario CQ60-220US PC Laptop
Entire Keyboard and Touchpad don't work! Compaq Presario CQ60
Fantastic, thank you for posting above that removing the battery sorted the problem. I had exactly the same problem as you with being able to sign in with my password but neither the keyboard or touch pad worked past this point. It's weird that the keyboard worked for signing in with the password but then didn't work anywhere else. Wonder what causes the problem coz I can't think of a logical explanation. Anyway I didn't have to hold the on/off button down for 2 mins. Just removing the battery and then replacing it cured it. I can't thank you enough for helping me to solve this.
Nov 09, 2009 | Compaq Computers & Internet
Compaq presario cq60 keyboard
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
Sep 14, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ60-212US Notebook Logo
188 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
