Reset or shutdown while reformating - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 24, 2011
Laptop shutdown while reformating
Place your OS disk in the DVD/CD drive and try again.
Nov 24, 2013 | Computers & Internet
On start, I get a "No bootable device--insert boot disk and press any key" message
This means that the Boot sequence part of Windows has becoming corrupted. If the FIXBOOT boot command does not work for you during the repair option, when inserting your system discs, then you have no alternative than to reinstall Windows.
If there is data on the drive that you need, then I would advise getting a USB to hard drive adapter and transfering the files to another PC before reformating.
This fault usually occurs during incorrect shutdowns,, hard resets, or power loss whilst the computer is switched on.
Mar 07, 2010 | Compaq Presario 700 470024-192 Notebook
The sansa froze
press the power button for 15 seconds and it will shutdown itself. then try reformating your sansa using the sansa updater..
Aug 12, 2009 | SanDisk Sansa e250 MP3 Player
Shutdown without notice
well try reformating your pc. maybe a virus trigger that behavior. trust me..
Aug 02, 2009 | Acer Aspire 5100-3357 Notebook
Error 12 sys reset
Usually caused by a faulty or inadequate power supply failing to get the drive spinning up to the required speed.
I'd try replacing the power supply with one that matches the specs in the manual first to see if that fixes the problem.
If it doesn't you're looking at a possible hard drive reformat which will mean taking the drive out, hooking it up to a computer, reformating and then placing the drive back into the DP02.
Fortunately in most cases its a simple matter of replacing the power adapter.
Good lick.
bd.
Dec 27, 2008 | Tascam 2488 Portastudio Multitrack...
Start up problem with HP laptop.
Try to read this link:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578
Try the "Recovering from the recovery disks" section but it only works if you have a special partition that cannot be re-format/re-partitioned inside called "EISA partition". all your data will be gone though.
Dec 23, 2008 | HP Pavilion zd8000 Notebook
Reformating Laptop
Pierre jas:
What diffiulty you are facing in reformatting? You should just put the CD (the original OS CD which came with the laptop and restart the laptop). If you do not have the CD you an just simply put in any operating system CD in and restart the laptop and follow the steps. Make sure when it ask you to perform a quick formatting just select NTFS formatting. Note: I would suggest to back up all your important documents before you do that as everting will be gone once you reformat your hard drive. If your machine is shutting down before it let you save anything, on the command prompt simply put the command 'shutdown -a ' quickly save your work to an external hard drive and after that you can reinstall your OS(operating system).
Hope that helped!
Nov 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Shut down problem
May be you have to check the power management settings which will shut down the compter when you press the power button.
First update the BIOS to the latest version before Installing windows.
You can see the instructions with iamge here
http://www.theeldergeek.com/shutdown_issues_in_xp.htm
Check the following links which can help you :
http://support.microsoft.com/kb/308029
You can try the registry editing option available here
http://www.zdnetasia.com/insight/software/0,39044822,39086135,00.htm
http://www.aumha.org/win5/a/shtdwnxp.php
Good Luck.
Live, Love, Laugh.
Apr 29, 2008 | Computers & Internet
Boot up problem
have you gone into safe mode? f8
Dec 18, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
