Question about Acer Aspire 4315 Notebook
My wireless cannot work. the network controller has a yellow sign
    President:
  • Acer Master
  • 2,246 Answers
You need to install network contoller driver
insert your cd driver
at device manager, right click at yellow sign then chose update driver
follow the instruction until finish and yellow sign disappear
try to connect to network
Posted on Mar 24, 2011
  • 206 Answers
The Yellow sign indicates that the the Driver for the Wireless Card inside the Notebook is not installed properly. Please uninstall and re-install the Wireless Drivers of the Notebook which is provided by Acer.
I do not know how to enable the wireless internet on my Dell Insperon B130.
1st try / keep hold of FN and press the appropiate F key (for example FN and F8 together)
2nd try / There may be a little switch at the front of your laptop, just below the mouse pad and keys.
3rd. try /Click start, control panel, network and internet, and then connect to a network.
Click on the wireless network you are trying to connect to and type any password in (if any password is required)
Hope thsi helps and please rate, Thanks
Mar 16, 2011 | Dell Inspiron B130 Notebook
Lenovo 3000 C100 problem, I have lost my wireless connection to the internet and cant seem to get this working again. THe laptop works windows XP
First please check if the wireless connection drivers are installed.
Please click on start -> Run -> type "devmgmt.msc" with out quotes and click on ok.
This will open Device manager.
In the Device manager, click on the (+) sign beside Network adapter and check if you can see the wireless adapter entry.
If you have any yellow exclamatory marks or red cross mark, you have to install the driver for the device.
If you cannot find the device under network adapters, check if you can see any entry that says as Network controller under other devices.
If so installing the driver should resolve the issue.
If you cannot find the entry in both the locations, then the issue would be with the hardware. Contact the Manufacturer for the service options.
Mar 15, 2010 | Lenovo 3000 C100 Notebook
Dell Dimemsion 9100 cannot connect to internet. Windows cannot repair the problem. Tried Windows and Dell drivers for network adapter with same results. Yellow caution sign on network icon.
Hi there
I can understand your issue.
When you same yellow caution i believe the network driver is not installed properly. To resolve this issue please go to device manager.
Locate for the network adapter and click on + sign to explore it.
Below that you can see your network device name, right click on and click uninstall.
Then reboot the computer and that will try to install the network driver ( It works in XP & VISTA). Cause XP & VISTA has the ability to load the default driver.
Then try to reinstall it and that should work.. If still the same issue kindly revert.......
Jan 14, 2010 | Dell Ethernet Card Network Adapter
Wireless problem
if you have vista right click on my computer goto properties devise menager if any of them have this sign !!! with /_\ trangle yellow coluer right click on it search online. for any other problem email me [ ariftariq12345@gmail.com ]
Nov 18, 2009 | HP Pavilion dv4000 Notebook
Can't connect to my wirelass network
CHECK THE FOLLOWING AREA FOR ANY SIGNS OF RED, YELLOW MARKS, GREEN MARK MEAN THAT IT IS WORKING NORMALLY.
GO INTO THE CONTROL PANEL, OPEN DEVICE MANAGER, CHECK THE FOLLOWING FOLDERS, WIRELESS DEVICE.
NETWORK ADAPTER.
NETWORKING AND SHARING, SHARING INFORMATION WITH EVERYONE, YOU ARE GOING TO DO THIS UNDER THE ADMINSTRATOR ACCESS
PROBLEM AND REPORTS: THIS WILL SHOW WHERE THE PROBLEMS ARE ACCURING AND HOW TO RESOLVE THE ISSUES THREW THE COMPUTER OR ON LINE, I RECOMMAND THE ONLINE IF YOU HAVE THE ABILITY.
SECURITY CENTER: TURN EVERYTHING OFF UNTIL YOU GET UP AND RUNNING.
SYNC WORKS IF YOU HAVE A PLUG AND PLAY DEVICE.
DISABILE THE WINDOWS DEFENDER AND FIREWALL UNTIL YOU RESOLVE THE CONNECTION ISSUE.
Apr 25, 2009 | Dell Latitude D600 Notebook
Wireless enable problem
Check under Device Manager first. That's under Network Adapters. If you see a thing called Network Controller under Other devices, the driver for your wireless card has not been installed. Simply reinstall it by right-click > Update Driver. But if you see your wireless card there with yellow caution sign, the driver needs to be reinstalled. With red X, that mean its disabled, right-click it and Enable. If no wireless card under device manager, your built-in wireless card is busted, you need to buy a separate notebook adapter. Good Luck!
Mar 24, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Wireless connection: computer says device unplugged, but it's not. All the settings are correct, but still cannot connect to home network. Used to work before computer software (Win XP Media Edition) was...
Hello Michael,
Windows XP Media Center Edition (MCE) does not normally say cable unplugged. I think you are looking at your Local Area Network (LAN) connection. Make sure your wireless card drivers are installed, and the device is enabled.
1. Click Start
2. Right Click My Computer
3. Click Manage
4. Select Device Manager in Left Column of Newly Opened Window.
Make sure your wireless card does not have a yellow caution sign on it, and make sure your wireless card also does not have a red X. (If you when you select device manager, no devices show that right away, then it should be ok)
If there is a yellow caution sign, you may need to install drivers or your device is having some sort of issue.
If there is a red 'X' on the device, right click the device, and select enable. Again verify there is no caution sign.
Make sure your wireless radio is also turned on.
Let me know if you need further assistance.
As a reminder, if this post helps, please rate it. Thankyou.
Feb 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
My internal wireless wont work. Am pressing the wireless button but the light doesnt come on
go to network connections in control panel and right click on the wireless network and click enable or connect, if it still doesnt show any sign of connection then you may have a hardware fault
Aug 31, 2008 | Computers & Internet
Wireless connection
Hi Kazmerr
Re: Dell Latitude d600
Assuming you already turned your wireless, your distance should be in range fom your router. Turn off and on the switch  or you can press Fn+F2 to start your wireless connection.If thats a no go check your wireless client  and make sure no other wireless client is installed ie. your ISP wireless connection manager.
Other work around for this is : make sure you have enabled or started your wireless client for windows by ff the steps below :
Win XP Sp2: start > control panel  classic view> administrative tools > services > then look for Wireless Zero Configuration and right click it and choose start or restart . After doing this you may check or view your available wireless network again.IF no go >
For winXP or VIsta ONLY
Go to start > control panel   { classic view } > system > device manager > Look for network adapter {+} sign > look for 802.11g wireless / or anything that says 'wireless' and make sure that theres no yellow question or excamation mark on it and IF none right click it and choose remove/uninstall> then restart PC > and try to view avaialable wireless again by ff the steps above.
{ tthis will refresh your wireless network hardware and software}
Note: for yellow exclamation marks or questions marks on your wireless adapter you MUST reinstall your DEll Wireless adapter. using you DELL System Recovery Disk.
In most instance it has somthing to do with your wireless switch on your laptop. With all possible steps porvided above doesnt woprk pls notify me. Thanks and good luck.
Jun 11, 2008 | Dell Latitude D600 Notebook
Acer Aspire 4315 Notebook Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
