Question about Kenwood KRF-V5060D Receiver
Hi, my speakers are starting to sound a bit weird and i think its cause of pplaying around with the equalizers and settings on the Kenwood Amplifier, am just wondering if there is a reset button to restore all settings to defualt?
    Brigadier General:
  • 8,546 Answers
Why guess? Get the manual out and actually look at the settings to see if they're out in space somewhere. If you don't try to understand what went wrong you will repeat it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KRF-V5060D-Receivers-manual/id/480bh229/t/2/
Page 33 if you want the shortcut to factory settings.
Posted on Mar 24, 2011
Hi, I have a problem with my neo laptop. There is no sound from the internal speakers. I have uninstalled and reinstalled the audio driver and checked that it is up to date. There is only a brief muffled...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | NeoWave PC Audio Graphic Equalizer...
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
No sound from my woofer
Check your speaker connections... try using a multimeter set to "OHMS" and see if the speaker is reading around 4-8 ohms... if it shows no reading there is no continuity in the coil of the speaker
Mar 24, 2009 | Kenwood KAC-929 Car Audio Amplifier
Rd-700
power amplifier will increase sound level-try graphics equalizer and connect it between the roland and the mixer(ask sales man which equalizer is more suitable for use with roland and behringer.
Jul 18, 2008 | Audio Players & Recorders
No audio - Pioneer Amplifier A-Z370
I experienced something similar.
Symptom: After use the sound cuts out together with a mechanical click (relay sound). Turning off and waiting a bit before powering on, tends to 'fix' it, but the sound cuts out in the same way after a while.
The click led me to the little relay board inside. Inspection of the solder joints showed that a few were 'broken' ("cold soldered"). This was right below a high-wattage resistor, possibly the cause of the stress causing these random disconnects.
Fix: Resolder the joints.
Jan 02, 2008 | Audio Players & Recorders
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
On and off switch
This is the thermal overload for the amplifier section. unplug unit and check all speaker connections for a crossed wire. After all connections are checked and are in good condition, plug the amp back in and power up. Note: the polarity of the speakers when the wires are plugged in. Use the painted line on the speaker wire as a guide for which one is positive(+) and negative (-). If an amplifier is operated out of phase for too long ( positive and negative reversed), you can damage the amp. A bad speaker coil can cause the overload as well. If it still does it, disconnect all speakers and power it up. If these remedies do not solve it, you amplifier IC is shorted and needs replaced.
Apr 10, 2007 | Kenwood AR-304
Kenwood kac x621 kenwood kac6402
May i suggest removing the equilizer unless you can adjust the settings for each amp seperatly. The amps themselves will allow you to add bass boost and treble boost. I think the problem your having is trying to run to much bass through your system causing it to distort badly.
Feb 25, 2007 | Kenwood Excelon KAC-X621 Car Audio...
Kenwood KRF-V5060D Receiver Logo
107 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
