Question about SPARKLE Computer SPARKLE SXT430512S3LNM GeForce GT 430 (Fermi), (512 MB) 64-bit DDR3 PCI Express 2 0 x16 HDCP Ready Low Video Card
I have sparkle sxt4301024s3lnm GT 430. i tried it to 3 different computer but still my screen monitor will get blue and sometimes it keeps on restarting; spec: amd athlon II x4 asrock A880G+ 2 gig ddr3 ram 500 gb 7200 rpm hdd 2 pcs. asus p5nsli intel dual core e5300 2.6 g 2 g ram 500 gb hdd
  • 11,800 Answers
The video card is defective - replace it. And do not use it in the mean time, it causes corruption in the Windows installed on the pc.
Posted on Mar 27, 2011
Why did my screen turn light blue lcd1712 ?
Please try to connect your computer to a different monitor. It may be that you're experiencing the notorious "blue screen of death", but you will be able to determine whether that's the case by trying another monitor. Please keep me posted. Thanks!
Aug 06, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Today, my monitor went to a multicolored candy-striped screen. I have to keep unplugging it (at the back of the monitor) until it works again. Every time I plug it back in, it's a different weird screen...
1) Replace the Monitor Cable, VGA is generally a Blue connection and DVI is a cream/white.
2) Make sure there aren't any bent pins in the end of the cables
3) Try the monitor on another working computer to verify it works or not
4) Replace the monitor.
If the monitor works on another computer then chances are that your computer has corrupted video drivers or a bad video card.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My packard bell lcd monitor shows orange then sometimes green light but has totally black screen. If power supply giving insufficient voltage would this cause above problem?
> insufficient voltage cause ?
Well, anything is possible, but other things are more likely:
1. loose connections of the "data" cable between the monitor and the computer's video-card;
2. an electrical "short" in the data-cable;
3. a "dying" video-card.
So, try the "free" stuff first:
Check the connections.
Try a different cable.
Try connecting the monitor to a different computer (laptop?).
Try connecting a different monitor to your computer's video-card.
Then, consider buying & installing a new video-card.
Nov 18, 2009 | HP Computers & Internet
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
Most times when i turn on my computer, the screen flashes.
it means your computer has caught the ati2dvag bug. This bug seems to affect ATI video cards.
The 2 most common “solutions” are:
  • Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found here on the ATI website.
  • Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
Jul 06, 2009 | ViewSonic VX910 19" LCD Monitor
New graphics card, no picture
1. Try to start in SAFE Mode by press f8 while booting. If successfull.
2. Press F8 again select enable VGA mode and continue.
3. Your monitor is not supporting the resolution reduce and restart it will work fine.
4 To reduce the resolution desktop right click, select properties goto tab setting - reduce resolution
Jan 14, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Nov 30, 2008 | ViewSonic Computers & Internet
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blank monitor
Sounds like the LCD mother board is bad. I have the same problem. The board cost $75 at sva-usa.com. I trashed it and bought a use Dell LCD off craigslist for $60.
Nov 05, 2006 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SPARKLE Computer SPARKLE SXT430512S3LNM GeForce GT 430 (Fermi), (512 MB) 64-bit DDR3 PCI Express 2 0 x16 HDCP Ready Low Video Card Logo
143 people viewed this question
Top SPARKLE Computer Computers & Internet Experts
David Payne
David Payne
Are you a SPARKLE Computer Computer and Internet Expert? Answer questions, earn points and help others
