Question about Qca Spas Paradise Hot Tub
Hi. We have a 10 year original owner Hydropool spa which we have replaced alot of stuff in the past 6 months. It now reads HO or something close to that and won't get past the 50's - 70's for temperature. Very cold in PA right now. Everything else seems to work. Any suggestions are very welcomed. We have put quite a bit of money into this and this makes me sick that something else is wrong. Thanks gain.
  • Qca Spas Master
  • 1,384 Answers
The code might be FLO and could be the circulation pump has debris in the impeller so when idling it should have pretty good flow coming out of the jet the heater uses. other common failures with heat are the pressure switch seen pictured. let me know and pictures help me help u
Hi. We have a 10 - hayward-fdxlwps1930-water-pressure-switch-replacement-for-hayward-universal-h-series-low-nox-pool-heater_16953382-5wza5llwn2qwnlqvdjcvdeqf-3-0_0.jpeg
Posted on Aug 02, 2017
4 Suggested Answers
  • 366 Answers
SOURCE: Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Posted on Mar 20, 2010
uspartscente
  • 717 Answers
yes although you probably have this fixed by now. Sounds like your sensors are bad, your filter is dirty(so there is not enough water flow) or one or both of your gate valves might be closed. My best guess is the sensor(s) is bad.
Posted on Sep 06, 2010
adamh294
  • 310 Answers
SOURCE: I have a Paradise II,
If this is under warranty call the manufacturer. If it was purchased at a big chain store like cost-co call them. It is very common for hot tubs that are shut down most of the year to have these problems. The motor shaft seals need to stay wet, but when shut down they are dry. When they go dry they shrink, causing leaks, which will in turn let water leak into the motor housing, which will in turn seize the motor bearings. It is much better once you have it up and running to run it year round, and when not in use, turn down the temperature as well as switching the controls over to "economy" Every spa made in the last 10 years has this setting. It will cost $.25 /day to run like this (about) which is way cheaper than service labor and parts. If you have a good spa tech. he should be able to replace the bearings for $35 each plus one hour labor per pump. If you have a bad spa tech. just pay to replace the pumps or do it yourself.
Posted on Oct 27, 2010
What can I do to past auto inspection?
Because of lack of information (data) about your inspection, it is hard to tell where the failure is.
For more information about changing catalytic converter. The price can be 10 times different.
The highest quota I got was over $1400 (the golden smog station), the lowest was below $200 (found by state division where I asked for compensation due to old car -- since I cannot go there directly, I paid $325 fro an agent to do it). Dealer was asking for $700.
After changed a home genie catalytic converter, which worked better then the original manufactured till car is dead in another 10 years, I brought it back to the golden smog station for free re-test. The technician did not believe that is a new, and inspected to verify that is true.
This homegenie catalytic converter passed a number of smog tests till car is dead after another 10 years.
BTW, the original manufactured catalytic converter failed on the very first smog check at year 6 or 7 after can was bought, so it is possible you had a failure catalytic converter, but inspection result may tell.
Jul 21, 2014 | 1990 Toyota Camry
Hydropool hot tub
see if voltage from transformer if ok board
Oct 07, 2017 | Pool & Spa
Spa pack reset
Was there a solution for this?
Sep 06, 2012 | Pool & Spa
My Latitude D520 * 09/09 - I replaced the original 60 GB with a Seagate 320 GB to optimize. * 05/10 - It died. Replaced with Seagate Replacement of 320 GB. * 07/10 â?? It died. Replaced with a...
I'm not sure that there is an "Optimum" hard drive for your Latitude. If you are replacing hdds this quickly there is something else that is causing them to fail. Nearly all hdds have a minimum of 3 year warranty and many have a 5 year warranty. If you are having multiple failures less than 5 months out on every hdd then the issue is likely with the Latitude and not the hdd. Your power supply/brick may be the issue.
The fact that this brand and model of laptop were reviewed by laptop review back in 2006 tells me that this laptop is well past its life expectancy. IMHO it is time to upgrade and stop wasting your time on old (10 years +) equipment.
Jan 05, 2018 | Dell Latitude D520 Notebook
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Qca Spas Paradise Hot Tub Logo
96 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
