Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I have a bissell 9400 2x proheat. the brush motor that drives the rollers keeps blowing up.could you tell me what the problem might be.
SOURCE: No water from my Bissell
The sprayer nozzles were all plugged. Even the one at the end of the upholstery hose. The vac started working again once I got the nozzles cleared.
Posted on Mar 31, 2008
  • 17 Answers
SOURCE: My Bissell ProHeat 2X model 9400 won't spray from
Here is what to do
Posted on Feb 08, 2010
SOURCE: Anyone know why my Bissell Proheat 2X Turbo Model
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Posted on Feb 27, 2010
  • 184 Answers
SOURCE: Brushes aren't turning on Bissell Proheat 2X and
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: I need a Bissell Proheat 2x assembly drawing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
j
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
The brushes on my Bissell Proheat 2x shampooer won't turn.
You need to replace the belts on the roller brush. Here are the belts you need:
Bissell Proheat 2X Belts
May 24, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brushes aren't turning on Bissell Proheat 2X and it is almost new.
Good luck.
Apr 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Scrub roller wont spin
pull the bottom cover off and replace the drive belt for the brush drum, if the belt is ok then replace the drive motor for the brushes.
Jul 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Roller brushes siop after a couple of seconds
heatman101
87uyf
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush roller not working on Bissell proheat 7920
my brother changed the roller belt, but now the rollers won't stay up so I can move the cleaner and the water isn't getting sucked up.
Apr 17, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
79 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
