Question about KitchenAid Classic Stand Mixer
Replace plug on mixer - KitchenAid Classic Stand Mixer
I have to go up to 3 or 4 before the mixer will start
Does the mixer operate on the lower settings once you've got it going at the higher speeds?
If so the motor mechanism may need to be serviced (cleaned). OR it could be the switch mechanism is either 'dirty' (maybe with built up flour?) or has failed and needs to be replaced.
While UNPLUGGED, move the switch back and forth from OFF to full speed many times, if you have compressed air, blow that into the slot around (top & bottom) while operating the switch.
Set to OFF, plug it in the mixer and try it.
If that doesn't fix the problem, then consider having the mixer serviced or replaced.
Nov 27, 2015 | KitchenAid KSM150PSMC Mixer
How to reset the fuse if there is one?
Have an electrician test the socket that the mixer plugs in to and see if there is electricity there. You might also plug in something else to test it yourself. If the socket its good, your mixer is "broken".
If the socket is dead, you need to reset the breaker, or replace it.
God bless your efforts.
Jun 01, 2015 | Food Mixers
How to replace the fuse
Open the plug and replace like for like then close up the plug again
Aug 01, 2014 | Bosch MUM4420UC Compact Series Stand Mixer
My Kitchenaid Mixer Model KSM150Ps is tripping my breaker after replacing the speed control board.
Try a different Receptacle outlet if it trips that breaker you know its the mixer, and there will prob be a short/loose connection somewhere
Nov 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I have the 300 watt hand mixer and the retreactable cord no longer holdes when pluged in. It's been broken for some time. Is there a fix to this problem.
The prongs on the plug have worn, and the plug can be replaced (for less than $2 USD) from any
hardware store, just cut off the old plug, and wire the new plug onto the cord.
Remember to keep the cord's conductors correctly oriented: the conductor on the Bravetti Hand
Mixer that have the uncolored stripes (in the insulation) is the Neutral conductor, the other is the Hot conductor - assuming your abode is wired to standard US 120VAC.
Aug 08, 2011 | Bravetti EP552H Hand Mixer
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
I need a new chord .
The cord is item #26 in this parts diagram. You can order it from Kitchenaid, or you can cut the old plug off the end and put on a new plug.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Pull the plug from the wall outlet. Remove the mixer's end cap and you will see the wire coming into the mixer thru a strain relief bushing. Push it in and then the cord will be easy to remove.
Apr 06, 2010 | KitchenAid K45SS Classic Stand Mixer
Need to replace a cord on a 30 quat hobart mixer and need to know where positive negative and ground go
I need to know if the mixer is 1 or 3 phase.Look at the plug---does it have 3 or 4 prongs?
Nov 30, 2008 | Hobart D300 Stand Mixer
My mixer motor doesn't work
check and replace the plug fuse and internal fuse of the mixer
Oct 13, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
KitchenAid Classic Stand Mixer Logo
47 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
