Question about DFI 661GX-MLV SIS661GX CHIPSET SOCKET775 AGP MATX RETAIL Motherboard
I can't install w7 with 1TB brand new HDD, screen display boot MRg fairlured, insert system disk and press enter, what problem with my PC? please help to solve it. Thanh a lot.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Do Try these installation Procedure
1.) Boot from "WINDOWS 7" DVD;
2.) Select "Repair computer";
3.) Select "Cancel" to exit the repair wizard;
4.) You will now get a screen which displays 'command prompt','system restore','memory diagnostics',etc......
5.) Select "command prompt";
6.) Type your "DVD-DRIVE LETTER" in command prompt, press ENTER;
7.) Now if your Windows 7 is installed in C drive, type "copy bootmgr c:\" without codes, press ENTER;
8.) After successful copy type "exit" without codes, press ENTER;
9.) Reboot computer;
10.) Select "start windows normally";
Posted on Mar 24, 2011
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
I am using HP Pavilion DV6767tx.i lost my recovery disks and my hp recovery also does't work my notebook does not start i want to change my os . plz help me
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
format whole HDD, craete a partition and then install the OS of your choice. ,
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
Let it complete the installation an dthen you are good to go.
Sep 05, 2010 | HP Pavilion N5415 Notebook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
your system either does not detect a bootable disk, or the HDD has failed. Disconnect any floppy disk, USB storage devices connected to the computer and make sure the HDD with an OS installed is the primary boot device. If you get the same error, remove and reconnect the hard drive. If all else fails, try repairing or reinstalling Windows. If nothing works, you may need to get a new HDD.
Aug 25, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
I can't installation windows xp. any solution?
Step 1 - Start your PC and place your Windows XP CD in your CD/DVD-ROM drive. Your PC should automatically detect the CD and you will get a message saying "Press any key to boot from CD". Soon as computer starts booting from the CD your will get the following screen:
Step 2 - At this stage it will ask you to press F6 if you want to install a third party Raid or SCSI driver. If you are using a an IDE Hard Drive then you do not need to press F6. If you are using a SCSI or SATA Hard drive then you must press F6 otherwise Windows will not detect your Hard Drive during the installation. Please make sure you have the Raid drivers on a floppy disk. Normally the drivers are supplied on a CD which you can copy to a floppy disk ready to be installed. If you are not sure how to do this then please read your motherboard manuals for more information.
Step 3 - Press S to Specify that you want to install additional device.
Step 4 - You will be asked to insert the floppy disk with the Raid or SCSI drivers. Press enter after you have inserted the disk.
Step 5 - You will see a list of Raid drivers for your HDD. Select the correct driver for your device and press enter.
Step 6 - You will then get a Windows XP Professional Setup screen. You have the option to do a new Windows install, Repair previous install or quit. Since we are doing a new install we just press Enter to continue.
May 06, 2010 | Toshiba Portege M200 Notebook
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Disk boot failure
Technically you can copy all the data from one to another hdd but not the operating system
You have to install your operating system (windows, linux or MAC) on your new 500gig hdd and then copy your data from 60gig hdd.
Regards
Jan 22, 2009 | Avanquest DISK COPY & CLEAN (WIN...
Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Sep 21, 2008 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
jason
RajDeep Gautam
RajDeep Gautam
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
