No sound from them when hooked up - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 24, 2011
I put a Pioneer AVH 1400 DVD in 06 solstice have it hooked up working but no sound through speakers I have hot ground remote and speaker wires hooked up what other wires have to be hooked up 4 sound
If the car had an amplified sound system prior to removal you will need to turn on the factory amp. You need to hook up the blue wire with the white stripe. You may have a dedicated wire that you need to hook it to or you may have to hook it directly to the 2 blue wires for the power antenna. Now you may not have a power antenna but hook them up anyway. If that doesnt work you have a dedicated amp turn on wire. If you find that and it still doesnt work check your fuses for the amplifier with a digital multimeter. Replace any blown fuses that you cant find
Apr 17, 2016 | Pioneer Car Audio & Video
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
No sound coming from sound bar
what do you mean hooked up and then no sound, hooked up with dvd player in the tv and then no sound?. ok check the cable if no loose connection, replace if possible.if still doesn't work tried to hooked up in other component input in your tv unit just to ensure if the problem is with in the signal input board.
Sep 15, 2012 | Insignia Televison & Video
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Sony bravia 285 and xbox surround sound.
a HDMI lead has sound and video cables
Jan 11, 2010 | Sony Electronics - Others
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Clarion eqs746
more info would be nice...
what did you hook it up to?
Mar 23, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Computers & Internet Logo
13 people viewed this question
Alun Cox
David Payne
David Payne
