Question about Apple PowerBook G4 Mac Notebook
My Powerbook G4 screen turned off because it was unplugged and the battery is no good. This has happened before and I remember there was a simple solution (some combination of buttons; Control + Option + Power, or something to that tune)... but can't remember what the combination is now. Can you help?!
  • 112 Answers
It's called a Power Management Unit (PMU) Reset. Here are Apple's steps:
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
Posted on Mar 24, 2011
When I power up my PowerBook G4, I hear the startup chime but the screen stays black, nothing happens!! Is my screen turned off or something?
It seems likely that the PMU (Power Management Unit) has failed and needs to be reset. There are comprehensive instructions on how to do this at the apple support site. Apple Support: PMU reset
Jan 27, 2011 | Apple PowerBook G4 Mac Notebook
Turn on my powerbook G4 but there isn't a chime and nothing comes on the lcd screen
If there's no chime, your problem could be anything from a dead battery or bad AC adapter to a dead logic board.
Does the tip of the adapter on your AC connector light up? If not, that's a problem.
When you push the button on the battery, do you get at least two glowing LCDs? If not, that's a problem.
Otherwise, try the following: remove the battery and the AC jack to make sure the machine is off. Now insert the AC jack, and reset the power management unit by pressing the following multi-key combination:
Shift Control Option Power-button
Wait five seconds, then press the power button to attempt to start the computer normally.
The instructions above are for the 1.5GHz PowerBook G4; the instructions MAY be different if that is not your model.
Nov 01, 2010 | Apple PowerBook G4 Mac Notebook
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My mac G4 powerbook doesnt start up. There are
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive if necessary. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Nov 11, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
An area on the display it's not working. PowerBook G4
I'm sorry to say that you will have to replace the screen soon. That vertical black and white lines that appear is the early warning signs that your screen will soon go blurry, or have a partial screen, or have it just stop working. This happens from the many times the screen was lifted open and closed and the ribbon cables just need to be replaced. And since the ribbon cables can't be simply unplugged and then replaced, you will just need to get a new replacement screen.
-Luke
Dec 20, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Water damage
Unplug it, take the battery out and turn it on its side, like an open book and resist touching it for 2 days. If it happens to come up after, get a latex keyboard condom and count your blessings, if not, hit me back.
Aug 25, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Won't Charge
Common fix for this problem is a simple Power Management Unit (PMU) reset. This will basically re-sync the battery "brain" to the computer so they when when to charge and when to stop. To do this, simply turn your computer off, remove battery and power cord and hold the power button down for 7-15 seconds. Then you MUST wait 15 seconds after pressing the button before applying power or inserting battery. 75% chance this will fix your problem. If Not, Replace Adapter/Charger. They have a microchip in them that can go bad that senses when to send more current to charge battery. Apple motherboards are generally better built so I'm not suspecting that at this moment. Let me know what you find out.
Jun 10, 2008 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 Mac Notebook Logo
101 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
