Question about Dishwashers
Asko dishwasher top wash arm washes. The bottom wash are does not more.
  • 55 Answers
More often than not on Asko dishwasher the lower spray arm or filter will clog up causing this issue. The filter in the bottom twist out for you to clean. Check the lower spray arm holes they to will come clogged causing this issue.
Appliance & Refrigeration Repair
Posted on Mar 24, 2011
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
Our asko 3250 is leaving s film and the soap is not coming out of the reservoir. It just sticks in there. Thedishes also have a kind of crust on them.
Check to see that both upper and lower arms are working. You can do this by suddenly opening the diswasher about 6 in and observing if the wand arm on top is revolving. This is done by water from the lower arm being pumped up through a tube mounted in the lower basket that centers over the lower arm and upper arm. Check that the tube is clear. check that water from the lower arm center is being pumped. Check that the hole is clear. if you have hard water, then sometimes the holes get clogged up and the arm will not rotate.(just like a lawn sprinkler) The upper arm rotating is what washes the detergent out of the soap dispenser. To aid in cleaning the spray holes, pour some white vinegar in the bottom of the machine about two cups, and turn the machine on high temp wash. Do not let the mixture drain out untill you have cycled it about five times. When the wash cycle has about finished stop and restart. The acid in the vinegar will help disolve the calcium and hardened soap. After the finish rinse cycle, you can put a little lemon juice in the machine and let it was through, that way the vinegry smell will disapate.
Jan 09, 2011 | Asko 24 in. D3250 Built-in Dishwasher
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
The dishwasher fills up with water but will not spray water.
This is a comen problem here is how to solve it and prvent it in the future.
First you need to remove the wash arms top and bottom then look and you will see a few ole in the arms both sides these are more than likely blocked with small bits of food clean the hpoles and rinse the arms make sure all the holes are open and replace the arms.If this is the case in future scrape the plates off in the bin and rinse any loose food off in the sink before washing the dishes in the washer,give this a try and let me know how it went.
Feb 01, 2009 | Asko D1876 Dishwasher
Detergent dispenser
I belive your problem is the top wash arm.Make sure all your screens are clear in the tank.check the wash arm holes for obstructions and make sure there not cracked.let me know how you make out.
Nov 20, 2007 | Asko 1385 Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
179 people viewed this question
Top Dishwashers Experts
