Question about Daewoo Heating & Cooling
Where can I get parts for Daewoo air conditioner Model DSB-071L / DSB-091L I need a reciever signal board, the number on part is S/N: 3104398200
  • westden Mar 30, 2011
    Hi Can you be more precise to my problem. I want to know were I can get spare parts for Daewoo air conditioners. You sent me five general site to search, which I have without results. I have looked at dozens of these sites before enlisting your help but cannot find info on Daewoo parts. My expectation was that your knowledge of searching would resolve my problem. Regards DW
    Sergeant:
  • 194 Answers
Where do you live
Posted on Mar 24, 2011
Polar wind
control remoto DSB-070LH/091LH
preciso de um comando para ar Daewoo
Jul 07, 2013 | Heating & Cooling
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Hi i have a Daewoo DSB 180LH air conditioner but the previous tenants have lost the remote control, what can i do?
Hi Cladia,
I had exactly the same problem! Fixed it by buying a Universal All In One Air Conditioner Remote. Tried a couple which didn't work, but finally found one which did - the Chunghop K-1028E. I purchased it online for $20 inc delivery to Australia.
Good Luck!
Regards,
Will.
Feb 28, 2011 | Daewoo DWA-146R Air Conditioner
Hi, we are working on a Daewoo Split AC, model# DSB-180LHT nad we suspect the receiver p.c Board is processing the commands, as we live in Australia, i am having difficulties in locating a spare parts...
Hi, The Company in the first link below is supposed to be the aftermarket support point for Daewoo. Try here first: http://spares.alliedappliance.com.au/part_enquiry.php
The try this one.
http://spares.bigwarehouse.com.au/price_and_availability.php
Since you did not state any part numbers I am helpless to help you find a replacement. FYI most board failures that I have experienced were condensation / corroson/ water caused. The electrical runs on the boards end up shorting and then take out the PCB transformer and fuse if there is one installed.
Let me now if neither of these companies were not able to help you. I will search again via Daewoo corporate if I need to.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Daewoo DWC-121R Air Conditioner
Daewoo split system model DSB-242lhg. Wont work on heat green light is on but no hot air
Is the unit in heating mode? If so, are the filters clean? Have the system repaired if you cannot fix the problem.
Mat
Jul 15, 2009 | Daewoo DSA-122L Air Conditioner
Daewoo airconditioner not working
Try reset power to the unit and see if that will take care of it.
Mar 26, 2009 | Heating & Cooling
My Daewoo DSB 091L unit has started to drip condensate from the casing joint underneath the front drainage tray. I have cleaned the blocked drain pipe and proved the water drains away. The condensate drip...
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Mar 24, 2009 | Heating & Cooling
Heating & Cooling Logo
274 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
