Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Hot water comes in but does not stay hot thru the cycle.
    Problem Solver:
  • 10 Answers
Your heater is not working. Could be a thermostat, the element or even the timer or control board. Call for sevice.
Posted on Mar 24, 2011
No water coming into washer
Behind the dishwasher there is normally a two little taps 1 for cold water and 1 for hot water, check that the taps are turned the right way and are letting the water into the mechine. post back what you find.
Apr 05, 2010 | GE Nautilus 24" Built-in Dishwasher
Spray arm problem
pump is bad or the screen is clogged
Sep 23, 2009 | Dishwashers
2004 Dodge 1500 4x4 with 4.7 V8 getting hot. Replaced therm, water pump and tested Radiator. Still gets hot very quick. The water is cycling thru block, but not coming back into overflow when getting hot....
Do you have anti freeze in it? did you replce the radiator cap? is the fan clutch good? is the AC condensor full of bugs and the radiator? are you low on transmisson fluid? or Motor oil? all these will cause it to get hot.
Jun 30, 2009 | 2004 Dodge Ram 1500
Not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Electrolux Dishwashers
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool elec dryer
check your lint filter, take it to the sink and see if it holds water. it may be clogged from using fabric softner in youe washer.
Nov 08, 2008 | Whirlpool LER4634J Electric Dryer
Frigidaire lws3312d washer not filling up
check the water faucets on the wall and make sure that both hot and cold are completely open.
check the water inlet hoses for any kinks or leaks.
Nov 05, 2008 | Frigidaire CWS3600AS Top Load Washer
Will not automatically switch from washing spin to rinse.
check to make sure you have both the hot and cold water lines connected and the water is turned on. sometimes the hot or cold line will clog up and it will not fill up during the rinse cycle. the humming sound may be the water valve coming on but no water is coming thru.
if you have a warm rinse set it to that to see if this is the problem.
you can clean the screens on the water valve by taking the water inlet hoses off the machine and you can look at the screens onside.
if not it may be a timer problem.
Jun 26, 2008 | Roper RAB2121KW Top Load Washer
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
