Question about Canon PC1061 Copier
Dear`hope you help me `my copier is conon IR1022 `when i on the power give me messege with sound :System Error E100 `PLZ dear excellency help me best regard and garatiful hakimi
  • 1,219 Answers
E100 means laser section trouble, on some copier it will show E100 when the drum is worn out and you need to change the drum unit. But also the laser unit can be faulty.
First, try to replace the drum unit, then try to reconnect the laser unit, try to replace the laser unit or DC controller.
Hope that helps!
Posted on Mar 26, 2011
System error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum . Bob from mendit.
press the helpful button by.
Feb 02, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
System error e100
m/c on go additional key then printer then printer reset then yes then power cycle hope problem was solved
Jan 25, 2014 | Canon imageCLASS Office Equipment &...
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
I fixed a paper jam in my Imageclass D320 printer/copier which involved removing both panels and the ink cartridge to get the paper out. Now it says System Errir E100 and I can't figure out how to fix...
E100 is error for laser unit.
Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
Call service...
Hope that helps!
Aug 01, 2011 | Canon imageCLASS D320 Digital Copier
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Jun 02, 2009 | Canon iR 2020i Laser Printer
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
Systems Error E100
ERROR E100 is results when DRUM UNIT is not sitted properly , please check it is engaged with toner ( developing assy).
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon PC1061 Copier Logo
267 people viewed this question
old marine
old marine
