Question about Motorola Mobility CITRUS Smartphone
My Citrus won't charge. When I plug it in I get a pop up to manage my USB connection.
  • 437 Answers
Hi tara martel you need to go into the serrings. next you need to go into applicationsand select applications next you ned to go into development and seledct usb debugging. and stay wake . next plig yourcharger in and now it should give you the 4 choices . tone of these choices is to charge only on your phone. you can pull the battery. it will reset the phone you will need to make sure that it is set up for charging hope this helps.
Posted on Mar 24, 2011
I barely got this camera. It wouldn't turn on so I
What make and model camera?
Not all USB ports put out enough current to charge a battery. If you're connecting through a hub, try bypassing it and connecting directly. If you have another USB port, try that.
Apr 26, 2013 | Cameras
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My motorola citrus doesnt charge all the way
It because if you looked where you charged your phone it might be dent you might off but your charger and click moving i know that because in my droid razer i did the same and know it wont charged that's why i using my motolora phone
Jan 02, 2013 | Motorola Mobility CITRUS Smartphone
Usb connection notification, what does it mean, won't go away
it is telling you the cord is plugged in and it is asking what it is plugged in to
Aug 01, 2012 | Motorola Mobility CITRUS Smartphone
Need to clear space on sd card
The simplest method would be to connect your phone to your PC with your USB cable and mount the SD card on the PC. Plug the phone into the PC and pull down the menu bar on the phone. Tap where it says "USB connected - Select to copy files to/from your computer." The phone should pop up on your computer as a hard drive, and you can back up files and delete them from there.
If you don't have a cable to connect your phone to your PC, you can download a file manager app from the Android Market. I use AndroZip, but there are others like ASTRO File Manager or ES File Explorer. You can use a file manager app to browse the files on your SD card and delete them that way.
Dec 30, 2011 | Motorola Mobility CITRUS Smartphone
I had connected my flipvideo to my laptop, when I was finished I clicked on 'remove hardware' sign, as instructed. A mesage popped up to say it was safe to remove the flip from my usb port, however the...
Right click on my computer->properties->Hardware->Device manager. In device manager uninstall all usb root hubs under USB. And then connect your device and click on scan for hardware changes in device manager. Your device will be recongnized.
Jun 10, 2010 | Pure Digital Flip Video Camcorder
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Motorola Mobility CITRUS Smartphone Logo
462 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
