I need the drivers for this device. My Windows 7 computer cannot recognize my DVD RW since I put SP1 on.
    Scholar:
  • 114 Answers
Dear friend
we do not need any drivers for DVD or CD Drives
just disconnect your DVD drive and start PC
now after booting, shut down the PC and then connect the drive again
now restart the PC
your drive will be detected
if not the try running the add/remove hardware in control panel
Thanks
Gagan
Posted on Mar 24, 2011
I bought my computer a couple a years back windows 7 Last year it crashed i gave it to a friend who claimed to know how to repair. serial no. is displayed under the computer. build7601
The 'Windows Setup Could Not Configure Windows On This Computer's Hardware' error occurs due to unexpected issue happened with the Intel storage controller driver which was included in the released versions of Windows 7 and in the Windows Server 2008 R2. Well it is found by the Windows Technical Support team that this issue has completely being resolved in the Windows 7 SP1 and in the Windows Server 2008 R2 SP1.
Steps to fix the issue "Windows setup could not configure windows on this computer's hardware
Step1: Download phase
·Download all the needed appropriate drivers for the hard disk drive to smoothly perform this process
Step2: Working with another PC
·Get access to another computer which has full internet connectivity. One should click on the appropriate link to easily download the driver for the hard disk drive and it should either be 32-bit or 64-bit configuration process
Step3: Save mode
·Save the downloaded driver to the DVD or even in the USB flash drive which can easily be taken to the PC, you are installing the Windows operating to.
Step4: Load driver feature
    ·Next, start the installation process of the Windows 7 or Windows Server 2008 R2, and simply have an overview for the Load Driver feature. An option known as 'Where do you want to install Windows?' will be visible on the screen in the lower right corner.
    ·Connect your USB flash drive or even with external drive of the computer on which you're installing the Windows device as advised by Windows Tech Support team. Step5: Managing the DVD
      ·One can even take the Windows DVD out of the drive and put the driver DVD into the drive.
      ·Click on the "Load Driver" by simply clicking on the option which says that "it checks removable media for storage controller drivers" Step6: Windows set-up process
        ·Once you have carefully loaded the driver, simply continue with the Windows setup process.
        ·The Advanced Drive Format hard drive option will be recognized and Setup process will continue as expected.
        Explore our Windows Customer Support Toll-Free 1-800-213-8289 number which is available 24 hours 365 days in a year to assist customers as and when needed. Our services rates are exceptionally feasible to use and are matched up to user's expectations.
May 08, 2017 | The Computers & Internet
After converting my machine from window vista to window 7 my unit not detecting my dvd rom
Update windows through microsoft (SP1 especially)....update all drivers. Check device manager to verify no problems there. If a problem go to the pc manufacturers web and look for specific drivers for the model in question.
May 24, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Sir, In my lenovo y410 laptop i installed windows 7 after that i tried to burn win vista dvd.After giving options all the content on the dvd is safely copied then dvd rw opened after putting empty disc my...
First of all, try to put other empty disc(or other disc, which contains data) in your dvd rw. See if it detects your CD. If it detects that means the problem is with your empty disc. If the computer an't detect your disc, go to Control Panel and see if any device has yellow mark. Make sure that drivers for your devices of your computer are installed correctly. If some device has yellow mark, that means you need to install drivers for this device.
If the problem continues, go to http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
for additional information.
Apr 06, 2011 | Lenovo 3000 Y410 Laptop
My xp computer will not recognize the dvdrw. under hardware devices it shows the driver but with a yellow tab. the device is a liteon dvdrw 160p6s. liteon says in docs that it uses pnp service and not...
There are 2 types of dvd-rw discs, dvd+rw and dvd-rw. Some drives, especially older ones (since you are using XP) only support certain types. I run XP as well and many DVD+RW discs do not work for me. If this is the case, drivers arent your issue, its simply a hardware flaw. I would try experimenting with a different format, whether its + or - (plus or minus)
Mar 19, 2011 | Microsoft Windows XP Professional
Driver for dvd-r 8801 need a driver for dvd player windows won't recognise it
The drivers for DVD ROM drives are built into Windows and there is no download.
If Windows does not recognize th drive then it could be a hardware issue or possibly a BIOS setting is wrong.
Does the Windows Device Manager show an un-recognized device?
Apr 14, 2010 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Do I need software to get my comp to recognize a new Mad Dog Multimedia external DVD/burner drive?
Hello
Depending on which version of windows you are using, you might need to install the drivers for the device.
I know XP and older versions have a mush smaller internal driver database than windows vista or windows 7.
You don't necessarily need to install software to operate the device, just need the driver installed, then your computer will recognize the device.
Hope this can help you.
Kind regards
Andrea
Nov 15, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | Computers & Internet
How to Install Sony DRU-710A DVD-RW
Cd/dvd drives don't actually require a driver to run. They use "class filter drivers" which are supplied by a burning program like Nero or NTI. These "class filter drivers" only add functionality to the drive. Windows just uses a generic driver "MSCDEX" to run them.
A couple of things to try:
Uninstall the drive. Open Device Manager, click on the + sign next to CD/DVD ROM drives, right click on the drive and select uninstall. Exit and restart your system. When windows loads, it will recognise a hardware change, and will ask if you want to install. Before you click anything, insert the disc that came with the drive (if you have one). This should then install, if not, let windows search. If windows can't find anything, select "I will choose the driver manually" and look for your drive in the list.
Another thing to do, is download the most current Chipset drivers for your motherboard (which I would recommend anyway, even if the above worked).
Update the Firmware version and the internal drivers for your drive. These can be found here: http://sony.storagesupport.com/product/112#drivers
Also, update windows to the latest Service Pack (SP3 for XP and SP1 for Vista) if you haven't got them already.
If you have Vista, did you recently update to SP1 via Windows Update? If the answer is yes, please let me know.
Hope these solve your problem
Regards,
Tim
Dec 09, 2008 | Sony DRU-710A DVD±RW Dual Layer...
My burner does not recognize a new cd-r disc
Ok people. First it would be an idea to use a CD/DVD lens cleaner, and try again. If you are running any 3rd party software/drivers like deamon tools, uninstall them and try again.
I have used Nero 6, 7 and I now use 8. I run XP SP3 on my desktop, and Vista SP1 on my laptop, and I have never found this problem with Nero.
You may need to uninstall the drive and re-install it. Also update the firmware for the drive.
Also, could you tell me what LG CD/RW you are using, please
Tim
Dec 08, 2008 | Computers & Internet
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
