Question about Microwave Ovens
I've got a 2001 rover75, v6and air bag light is on,fault code comes as a P818f,which airbag would be faulty?
I have a NNSD297 Panasonic over the range microwave oven. First the unit had power, clock , timer, fan was working; except after hit the start button, maybe 2 secs looked like working then stops operating....
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Feb 11, 2013 | Panasonic Microwave Ovens
Krups XP7200: when I turn it on, after a few seconds all LED flash and error code 3 is displayed. Nothing can be done
The fault can be related to the program controller, so check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Aug 24, 2011 | Microwave Ovens
Micowave shows f3 willnot clear
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
The codes represent there is an error and as there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Aug 22, 2011 | Kenmore 61632 Microwave Oven
Light comes on, turntable working but no heat (microwave)
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
Jul 27, 2011 | LG Microwave Ovens
My oven turns on and seems to work (i.e, the light comes on and the table turns round), but the microwave is not heating up. What is the fault. ps the conventional oven parto of this microwave still...
HI..there is a heating filament of an oven..it s responsible of producing heat to the oven..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..
Jul 07, 2011 | Bosch HLK4555GB Convection / Microwave...
I select High/Med/Low, set time say 1 - 2 mins microwave starts up light comes on, fan comes on, table turns...but after 20-30secs table stops, light goes off, disply reverts to clock time, fan runs for...
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type. In this case it seems that the program controller board has errors specially if the oven heats and shuts off. remove the board, clean and reset.
May 16, 2011 | Microwave Ovens
Hello, I have a problem with my microwave type Sanyo em c-2000 Sometimes the microwave doesn't react after I press the start button. After the beep there's the following code in the screen:...
The error described can be fault in any of these.
Apr 12, 2011 | Sanyo Microwave Ovens
Light does not come on, first switch on of appliance and light does not work
If there is no action please do not switch on unless you have confirmed the fault.The door switch can be faulty and unless it contacts the light wont come on.
If microwave is not working check this out: It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Make sure that the program controller is working if not check power - step dwon suppy, the pads are responding- if not fauty pads- or the door switches ,if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on , use a cup of water inside to test.
If there is heating without any issues , you can use the microwave safely
Sep 27, 2010 | Microwave Ovens
My aquagard is probling from 2 months the red light is blink when we start aqua iam tired to complaining many times to service centre from where i did emi
The red light comes on due to a failure to detect the right intensity of light into the controller board. The LDR- light dependentt resistor - is fixed on to the cylinder which has the UV light. Hence the unit is clogged and the light intensity has dropped. You will need to open , clean and reset for the fault to go .Please take the top cover, the glass tubings and the UV lamp out very carefully not to damage.
If the fault is still persisting then the main board is faulty, sometimes the driver transistors are defective and will not output the voltage to the lamps. Please check this out and I am sure it will work. The service centres normally replace boards even if a transistor is faulty.... so your are right.
I hope my advice helps.
Aug 19, 2010 | Microwave Ovens
Microwave Ovens Logo
185 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
