Question about Marantz SR-7000 Receiver
Marantz SR 7200
Duncan,
having same issue...power immediately switches back to standby everytime I turn power on. It works for many months, had to take system out and put it back in correct ( hopefully...) and now this. Zapped huh? What could I have done to fry the outputs? Jim
    Novelist:
    Champion:
  • 218 Answers
Most often it is due to improper speaker loading. In other words, it needs to have from 4 to 8 ohms speaker load and you wired your speakers in parallel when they should have been wired in series. What would have been an 8 ohm speaker load in series, turns into a 2 ohm load when in parallel. And with dual voice coil speakers you just compound the problem. And don't even get me started on bridged outputs.
Anyway that is what usually causes an amp to fry. Good luck.
Posted on Nov 11, 2008
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
The receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Dec 29, 2009 | Marantz SR-7200 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR5001 Rapidly Blinking Standby Light
if u want to sove your problem then contact me on my number 9555503717
Jun 21, 2009 | Marantz SR-7200 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
Marantz SR7500 Home receiver, Digital CD will not play
Verify that the digital output is enabled. This is a switchable output. A brown-out or other power isseu may have shut it down.
Get back to us if that is not the case.
Dan
Mar 20, 2008 | Marantz SR-7200 Receiver
Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Jan 29, 2007 | Marantz SR-7200 Receiver
Marantz SR-7000 Receiver Logo
275 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
