Question about Car Audio & Video
How do I hook up my subwoofer and amp to OnStar
    Scholar:
  • 81 Answers
I assume you want the sub and amp for listening to music and not the onstar itself, just the vehicle has onstar? if thats the case the easiest way would be to hook a line level converter into the rear speaker wires (both right and left) this gives you a RCA jack output to connest your rca cables to to send signal back to the amp. run power to the amp as described in the wiring kit directions and hook everything up as the amp requires. the rca cables would go to the "in" on the amp and you can adjust the line level converter for output voltage ( increasing the level increases the volume before the amp, so be easy on the adjustments or you could blow your speakers.)
Posted on Mar 24, 2011
How do I hook up subwoofer sony cxs-gt08hp
NO!!NO!!NO!! Dont hook up just a sub to rca outputs. they run at around 2-3 volts and maybe 1 watt. the difference in the settings is for a sub amp(sub) or a amp for mids and highs (amp). the only way you will not need to run an amplifier is if you get a powered subwoofer, as these already have an amp built in.
Dec 24, 2012 | Sony Car Audio & Video
I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
Nov 16, 2011 | JVC SP-PW100 Subwoofer
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Can u connect another subwoofer to this sub? if so how?
Yes, you can connect another subwoofer too along with this unit, hook RCA pin in this subwoofer coming from amplifier sub out and there is RA jack line-out, anothersubwoofer can be plugged there. It is mentioned in user manual page-7 and previous expert gave you user manual link to download a copy.
Thanks.
Aug 26, 2010 | Sony SA-W305 Subwoofer
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
No sound coming from door speakers
In the yukon it has preamplify,if you disconnect stock stereo the amp is not workind unless you know how to find it. You gotta let the car-toy hook it up for you.
Aug 10, 2009 | 2002 GMC Yukon XL
Subwoofer out problem
Thats an installation error. I'm almost 100% sure whoever hooked up your amplifier hooked the amp turn on to your power antenna wire. If there is no amp turn on wire, the accessory wire will do.
Dec 31, 2008 | Clarion Car Audio & Video
Z2 install
Thats an expensive installation the harness alone is over 120 dollars. You will lose your onstar unless you get a onstar integration module. You will also have to bypass your amp
Mar 01, 2008 | Pioneer AVIC-Z2 Car DVD Player
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
