Question about Electrolux EIGD55HMB Gas Front Load Dryer with IQTouch Controls Mediterr
The metal vent where the heat comes out in my Electrolux EIGDHMB appears to have burnt some clothing. There is black burnt crusty stuff on the vent now which sometimes transfers to clothes or makes the whole load smell like turpentine or kerosene. I've never dried anything but clothes in there. How could this have happened and what can I do to remove it? Thanks for any help! I use fabric softener in the washer, if that matters.
  • 29 Answers
Most likely you dried clothing that had some sort of residue on them. Leave the dryer door open to air out. Try a solvent to clean residue off.
Posted on Mar 24, 2011
  • scndtonun Mar 24, 2011
    I've tried getting it off but it is BURNT on! Any idea of what type of product would work? Thanks!
  • gabe_t
    gabe_t Mar 24, 2011
    If that is the case the only option would be to sand it off or replace part.
Ihave a top of the line front load dryer with steam(electrolux). It "burns" or melts the clothes leaving a hard black substance on them. If I turn the heat to low I must run it 2-3X to dry the clothes. the...
Do not waste any more time with the repairs, they will not resolve the design flaw issue. We have also had the vent replaced 4 times and have burned thousands in clothing /bedding. We are pursuing a class action lawsuit against Electrolux. If you are interested in more information please email me at: alicat_95650@yahoo.com
May 20, 2010 | Electrolux Dryers
I have a Zanussi Electrolux ZSF6126 and the
Check to see if the heat element in the bottom inside is all crusty or cracked, if so replace, if not, unplug unit from house current, pull bottom toe panel off, you should see where heat element comes thru cabinet and has two wires attached, remove wires, take ohm meter and check for reading, if reading is ok then you either have bad control timer circuit (main board) or blown thermal fuse. Call tech to check further if you do not have original tech sheet or electrical background. My bet is that you have a bad heat element.
Nov 12, 2009 | Zanussi 24 in. ZSF6120 Free-standing...
There is heat, but drying takes two cycles
Clean out your dryer vent. Many times the lint and other stuff plugs up the vent and slows the dry time down dramatically.
Aug 05, 2009 | Whirlpool WGD5300S Dryer
No Heat
yes possible ellement burnt out or themofuse burnt out thermofuse is a small white or black device witch is mouted od the back of the interior panel about 1"
longif it has ovrheat this fuse will cut out the power to the ellement or if the vent outside was cloged thanks from gilles
Mar 15, 2009 | Dryers
Electrolux dryer burning clothes
All,
Not sure if this is a solution to the issues we are experiencing. However, I called Electrolux (877-435-3287) and spoke to a customer service rep (Peggy).
After I provided the information she stated that this is a known issue and Electrolux has a fix in place. She is sending new parts out to me today and I will have to call Electrolux back when I receive the parts to have a technician install the parts. The parts they are sending are, A Mister Exhaust System and a new Air Duct.
In addition, they are issuing me a check for $100.00 for the damaged clothes (100 wont cover it, but I thought it was a nice gesture, maybe you could get more).
Jan 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Clothes burnt?
Try turning down the heat setting on your dryer. This should help immensely. Dry these types of clothing on say "medium" setting and the heavier things on normal heat.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Hotpoint 761 washing machine, leaving metal particles in clothes
If you are itching, do you have an allergy?? to the powder you are using? if there is mold and you cant shift it, may be worth you talking to the manufacturer after seeing the doc. They will also recommend what powders for you to use with their machine.
Nov 23, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Electrolux EIGD55HMB Gas Front Load Dryer with IQTouch Controls Mediterr Logo
237 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
