Question about Samsung SyncMaster 2233BW 22" LCD Monitor
How do i get the back off of my 2232 monitor? It is dead.... no pic at all ... maybe bulb gone?
  • 30 Answers
The case is most likely snapped together. Check around the perimeter for any screws first, then use an old credit card to run around the edge to separate the plastic. Just go slowly and pry around the edge until you get the tabs to pop.
Once inside the back of the lcd, you should have two circuit boards. One will be for power and the other for feeding video to the lcd. If you have no video signal at all, then the problem will reside on the video board. However, if you have an image but the screen is dark, it may just be the bulb.
DIY bulb replacement is possible if you are familiar with electronics and soldering. Having it repaired professionally is usually close if not more than a new lcd.
Posted on Mar 24, 2011
No video signal to pc monitor
does the pwer light come on? might be the internal bulb has gone dead. if you look really close can you see the screen just barely? if so then its that, if not then its not that hope this helps..
Jul 12, 2012 | HP Computers & Internet
I have a 18 month old inspiron 1545 and suddenly its display went to dead black. But still windows is loading up i can hear sounds and music but can't see a single blink on the display. Don't know...
Hi paramvirgull...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s. If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 16, 2011 | Dell Inspiron 1545 Notebook
Install new charged rechargable batteries and will be dead batteries in bout 2 hrs not even turned on. take 2 pics and gone
Is your newly charged battery are new? Maybe your battery is worn out already. Or buy a new rechargable batteries and observe. Remember do not over charge your battery, this is always the reason why your battery got easily worn out. Thanks
Sep 11, 2011 | Kodak EasyShare C875 Digital Camera
I have used a flatron W1934S for approximately a year and then it just stopped working. The screen is blank and the blue power button is flashing. I temporarily connected the computer to another flatron...
I'm sorry to hear that you have a problem with your monitor. There are a few things you can try. If these won't work, probably something fried from the inside that killed the monitor. First of all, try disconnecting the power cable from the monitor, if this is possible. If the powercable is hardwired (meaning you can't disconnect it from the monitor itself) to the monitor, unplug the cable from the wall. Reconnect and see if this works. This worked with a monitor i had that had this kind of problem. If it's still not working, and the powercable isn't hardwired into it, try a different cable. If this doesn't work, the LCD bulb might have gone bad, and needs a replacement. You can find usefull tutorials on the web how to do this. If you can, check everything inside. If something fried, it's dead, if nothing is wrong, the LCD bulb has gone bad and needs a replacement. I hope i helped you, if you can't do this yourself, please go to a computer repair centre and let them take a look at it, and i hope this problem gets fixed fast!
Jun 28, 2011 | Computers & Internet
I am using benq monitor 17" but after some time
Sorry mate, i had one of them too, i called everywhere and ended up just buying a new monitor, shame, becos it's a waste.
Jan 28, 2011 | BenQ FP91G+ 19" LCD Monitor
Sony Monitor just gone really dark
Cold cathode lights behind the LCD screen are dead or dying. If you like the screen go on ebay and look for the cathode light kit if available. You can search google for replacing the lights on a LCD screen and its pretty straight forward. If its not worth your time just buy a new screen, but replacing the long skinny bulbs will make it like new.
Jun 04, 2009 | Sony Computers & Internet
How do I take the cover off samsung 930B monitor
The front and back covers snap together. Some come apart easily others are very reluctant and will break some of the retaining clips as you pry the front and back apart. Usually this does not result in a problem as there are enough retaining clips to hold it back together.
Most of these do not need bulbs. Usually just replace the power supply electrolytic capacitors that are bulging.
Monitor Mike
Jan 04, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor gone dull
there is a key on the keyboard which controls brightness. on mine it is the second key on the right, of the bottom row. it has a small sun on it. Press this key at the same time as the function key (on mine, bottom row, second from the left, blue key marked Fn) - and the monitor will brighten up.
Apr 19, 2008 | Computers & Internet
Washed out text
Monitors have brightness and contrast setup on them usually in a menu. A lot of monitors have a 1 button self correction that may work for you also
Apr 01, 2008 | Computers & Internet
Monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
