Question about Kitchen Ranges
I WANT TO KNOW HOW TO TEST A WALL SOCKET WHAT SETTING SHOULD I SET IT TO
  • 29 Answers
To check for voltage, select VAC on meter. electric ranges require 240 vac. common to L1 should read 120 vac, same for common to L2. L1 to L2 should be 240vac. Gas range only needs standard 120vac.
Posted on Mar 24, 2011
Canon MP210 no power
See that power cord is seated on both ends, Plug cord into wall and with a multi-meter see if you are getting voltage on other end of cord. Test wall socket. Try another wall socket. Replace cord.
Mar 30, 2015 | Canon PIXMA® MP210 Printer
Mycharger on my samsung table 10.1 tab 2 won charge please help
The problem might be that your battery is too old. Rechargeable batteries have a limited number of charges that it can undergo.. usually between 300 and 500, before it starts to not hold much power anymore.. If it's not the battery,
I suggest you test the charger.
if you have a multimeter/voltmeter, unplug the charger from the wall socket and tablet. Set multimeter to measure Resistance/Ohms.. Touch one end of your meter cable to one of the charger pins(that you would otherwise stick into the wall socket) & the other end to the end you otherwise stick into the tablet.. all you're looking for is 'some' measurement... if you get a reading, test the other pin (wall socket end of the charger) .. if you get a reading again, then your charger should be fine.
Next look at your tablet, where you stick the charger into.. does anything seem loose/out of place? if no.. call the shop you bought it from an ask for assistance over the phone (typically shops offer advice freely over the phone)
Nov 12, 2014 | Tablets & eReaders
BOX DOES NOT WORK
The wall power socket maybe faulty. Try connecting a lamp to the wall socket to test if it has power.
May 02, 2013 | Apex Digital Office Equipment & Supplies
Need to set up fax
check back side two telephone female jacks, indicated phone(extension) & wall socket symbols.. Give telephone line input in the socket which symbol indicates wall socket. once its plug in normally we can use it. If you want customized setting like ring to answer,silent detection etc..choose in fax function setting...once connected with tele line you can get faxes automatically..
Jan 31, 2012 | HP Officejet 5610 All-In-One InkJet...
Is there a way to set high with more than 6 hours ? I need to set mine for 20 hours in high.
Not unless there is a delay setting on the machine. You could get a timer plug to put into the wall socket. The type you use to ste lights to come on and off when away from home.
Dec 18, 2010 | Oster 7664-33 6-Quart Slow Cooker
I turn the hd vizio off, then I turn the power off to my residence to replace a electrical wall socket, which was in a different room of the residence. Upon replacing the the wall socket, I turned the...
Tries unplug,replug the tv back an hour later.The tv now,will reset itself back to the factory setting.The tv should work now,not than the power supply board got shorted some how.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 16, 2010 | Vizio Televison & Video
I have an LCD 1970GX monitor. I had to get a new
Your NEC 1970GX monitor as two video inputs; an old-school VGA socket (socket and cable connectors usually coloured blue), and a DVI-D digital socket (socket and connectors usually coloured white). Purchase either a new VGA-VGA cable, or if your PC has a white DVI-D socket, a DVI-DVI cable, both relatively cheap options and test this simple option before any further troubleshooting. Many computers and monitors will go to sleep (automatically switch off) after not being used after an adjustable period of time. If this is your problem, you will need to adjust the setting (in power options of both the monitor and PC) to a setting suitable to your usage. You can also, in power options, usually turn off "automatic sleep".
Oct 08, 2017 | NEC Computers & Internet
Right rear blinker not working!
check the socket whare the bulb goes for rust corosion. you can also test the socket by removing bulb and using a 12 volt test light. remove bulb and connect test light leads to the socket while the signal is on.connect one lead from test light to inner wall of socket and the other one to the terminals in bottom of socket
Jan 13, 2009 | 1995 Ford F250
Pv900 power amp 300 watts
Recheck your switches on the back sounds to me like you have the subwoofer crossover setting turned on.
Nov 12, 2007 | Audio Players & Recorders
Several Router problems
It sounds like an ADSL signal strength issue. Test that it is not a problem with the ADSL phone cable setup, using the shortest ADSL/Phone cable you can find (under 1Meter is best)unplug all other phone line using devices and filters from the wall jack points and test the routers connection again as the only device plugged in(this is Isolation testing) If the issue replicates itself under isolation testing conditions then ring your ISP providor and request that the "ADSL signal voltage" needs to be increased slightly as your router is not hearing the ADSL signal properly. If the issue doesn't replicate itself under isolation test conditions, you are either using an old or bad ADSL/Phone cable or your cable is too long (should not be longer than 5meters)or if you are using a wall socket/splitter for direct adsl access (without filters)then test the socket with a filter to verify the socket/splitter is not the cause of the problem, if you do use phone filters, during isolation testing, test each of the filters individualy with the router and see if the disconnection issue is replicated if so replace the bad filter the disconnection issue was being caused by phone signal interferance. Your third request requires you to setup the LAN info on the windows side of your connection not the wireless card, this can be verified by searching for websites via thier IP address which will work, when searching via their website name wont, DNS resolution issue, it is probably best practice to use MAC Addressing for your wireless setup though.
May 15, 2007 | Trendware TEW-452BRP Wireless Router...
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
