Question about Canon EOS-AE-1 35mm SLR Camera
My AE1 when I rewind it rips the film yes I pushed the black button on the camera any help?
    Brigadier General:
  • 3,006 Answers
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Posted on Mar 24, 2011
Testimonial: "thank's for the info. I posted a prob with my other camera PWR shot a85 and the help you gave me was great I have sent it to canon for repairs per rec"
  • jackomurph Mar 25, 2011
    you guy's are great thank's for your help I will tell all me friends what a great web site jack
Hello, just found my 35mm ae-1 camera. took some pictures and its not rewinding back up . little crank is moving but film is not going back in. am I missing a step?
Did you remember to push the rewind release button, on the bottom of the camera first? Failure to do so will either not allow you to rewind the film (without applying a lot more force than needed), rip off the film sprocket holes, damage the camera's internal gearing, or any number of other nasty things.
There should be a small button on the camera's bottom baseplate, press it in and it should rewind smoothly.
Sep 05, 2011 | Canon EOS-AE-1 35mm SLR Camera
My ae-1 rips the film when rewinding canon camera
Are you pushing the rewind button on the bottom of the camera??
Nov 06, 2010 | Canon Photography
My ae-1 when rewinding rips up the film
push the black button on the bottom of the camera before you wind it up. it's right there in the manual.
Sep 29, 2010 | Canon EOS-AE-1 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
Canon AE-1 won't rewind film without tearing it up.
misstigeress,
is the film being ripped along the sprocket holes? if so, the rewind button is not unlocking the drive sprocket. with film removed open the film door and push the rewind button in, the drive sprocket should turn freely. now charge the shutter with the advance lever. the rewind button should pop out and the drive sprocket should not turn freely.
if the sprocket did not turn freely with button pushed in, the camera needs repaired. there are no new parts for this model canon so any parts needed will be good used.
Nov 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Rewinding the film
The film will not rewind on its own. If you turn the camera over you will see a small slide switch with a small button next to it. Push the button in and slide the switch at the same time, the film should then rewind. Also the camera must be in the on mode.
Aug 05, 2008 | Canon T70 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Oct 04, 2007 | Nikon F60 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
206 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
