Question about Acer Aspire 5500 5570-2609 Laptop
Need to unlock password (Key:87605506) Any ideas? I can't use the system because I don't have a password and when I press enter it says Password check Fail. Press any key and when I do it says System continue and then the screen says No bootable disk - insert boot disk, etc.
    Problem Solver:
  • 8 Answers
Password: 38763528
Posted on Mar 24, 2011
My Asus computer turns on but I have no cursor and don't know how to unlock it. I can type but that is it help!!
Press the TAB KEY REPEATEDLY on your keyboard until the cursor is in your password box, and enter password then click enter!
Jul 12, 2013 | Computers & Internet
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Password reset acer aspire one d250 wont boot
Try these WEB sites for removing hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Mar 14, 2013 | Computers & Internet
I have an iBook G4 and don't have the administrator password. As i don't have the boot CD, i can't upgrade anything... how can i resent the administrator password without the boot CD?
You can reset your password with a few simple steps. 1. You must turn off your computer. 2. Turn your computer back on BUT, right after you here the chime sound you need to press the "command" key and the "s" key simultaneously. 3. This will cause a command prompt to come up instead of your usual desktop. 4. Type the following commands mount -uw/ (press enter) rm /var/db/.AppleSetupDone (press enter) shutdown -h now (press enter) 5. After rebooting you will have a new admin account which you can set the settings for under "System Preferences". Delete the old one if you wish.
And there you go! Hope this helped! Please rate my answer if you have the time! :)
Aug 24, 2011 | Apple iBook G4 Mac Notebook
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
Phone dial unlock
01 Press Function
02 Press Down button until menu "Change password" displayed -> ENTER
03 " Current password " : Press this Number "726276642" -> Enter
04 "New password"
05 0000 ENTER
06 EXIT
07 Press DIAL LOCK KEY
08 0000 ENTER
09 UNLOCK SUCCESS
Mar 23, 2008 | Lands Phones
Acer Aspire 5500 5570-2609 Laptop Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
