Question about Hayward Pro Series Side Mount Sand Filter 24" S244sv
Hired a person to install my pool pump and filter, he lost alot of parts and the assembly guide, so now I don't know what is missing or how it goes together properly. I would like a complete packaging list so I can put my pool filter together and make it work properly. How would I go about obtaining all this information on line? Thank you
  • 3 Answers
Google the filter model number or go to www.haywardnet.com and look for your filter and down load the service manual it will have a brake down of all the parts
Posted on Mar 24, 2011
Installed replacement filter. Water returning to the pool the pressure is very low. What can cause that?
Check to make sure the ball in the inlet and the outlet valve has not moved. If it is a plastic type plumbing one the ball can actually fall out of the the housing.
Personally I do not own a sand filter my pool came with a DE type.(6 of one a half dozen of the other). I would remove all the sand from the filter and see if the pump works as you think it should. After that it is a matter of figuring out the obstruction. Could be valves leaves, almost anything but it should be easy to locate.
Jun 21, 2015 | Hayward SAND FILTER, PRO SERIES
Polaris 380 wheels not turning
check wall fitting filter inside probably clogged and wont let water flow that's why plug blew out repair person should have caught that bad tech
Jun 24, 2012 | Polaris Pb4 - 60 Booster Pump
I have a Hayward Pro Series Sand Filter. I turned on the pump and water is gushing out of the side of the tank where a connection goes into the tank from the bottom of the valve assembly
I don't know but if there is a hole in the tank it should be connected and sealed to the lower valve pipe. If you are missing parts to the connection, they are available at a good pool supply store. If the tank is broken even those are available. I hope this helps.
Aug 21, 2011 | Hayward SAND FILTER, PRO SERIES
How to install the filter on the inside of the pool
I am not sure what you are asking because the filter is to be installed on the outside of the pool, not on the inside. The manual you got for the pool should show how to install it. If you don't have the manual then the main thing is to connect a hose between the skimmer port of the pool and the suction of the pump/filter and connect the return port through a hose to the return port of the pool. If you can't connect it then you are probable missing some parts. I hope this helps.
Aug 12, 2011 | Intex 1000 Gallon Swimming Pool Filter...
I LOST MY OWNER MANUAL FOR MY 18X48 EASY SET INTEX POOL AND I DON'T REMEMBER HOW TO SET UP THE PUMP AND FILTER
Attach the hose from the lower part (the pump) to the lower hole (intake) on your pool. The attach the hose from the taller part (the filter part) to the taller hole on your pool.
Open the spigot on both parts of the pool (turn, lift and lock into open position) openings. You'll hear water fill up the filter section. Make sure the knob on top of the filter section is a little open and let the air bleed out. You'll know when it is full of water when it starts spitting water out. Close the top then.
Plug in your pump and turn it on. If it doesn't take much water in at first, reopen up the knob on top of the filter to let more air out. Once it spits water, close that up.
Hope this helps!
Jul 14, 2010 | Intex Pool & Spa
How do I hook the pool to the filter and then to the pump
The outlet from the skimmer on the pool goes to the pump inlet (center part of the pump). The pump outlet goes to the filter inlet. The filter outlet goes to the return to the pool.
Jul 04, 2010 | Hayward Pro Series 18" Above Ground Pool...
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a...
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 01, 2010 | Hayward SAND FILTER, PRO SERIES
Fuel filter location/replacement My car is cutting out at 4000 RPM
2006 Mazda MX-5 Miata 2.0L MFI DOHC 4cyl
Mazda Car 2005-06 Repair Guide - Removal & Installation
The fuel filter on most Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir or as part of the fuel pump assembly.
The filter on Mazda3 models is part of the fuel pump assembly.
The fuel filter is part of the pump assembly. Once the fuel pump is removed, remove the filter retainer and filter. refer to the fuel pump procedure or removal and installation.
I hope help you. Good luck.
Oct 12, 2009 | 2006 Mazda Miata
Can i hook up a intex pump to a sand filter
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
Jul 13, 2009 | Intex 2500 Gallon Sand N Sun Pool...
Hayward Pro Series Side Mount Sand Filter 24" S244sv Logo
42 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
