Ricoh fax 2000L with error code 0-07h - Office Equipment & Supplies
3 Suggested Answers
  • 32 Answers
SOURCE: Fax error code on Ricoh 2045
network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
Posted on Apr 02, 2009
santosj27
  • 263 Answers
SOURCE: How we print a document on both sides (back and
Hello!
If your machine have that option you just need to go to the printer properties and select the duplex.
If you have any doubt reply to me.
See you!
Posted on Jul 07, 2011
Can send Fax but not receive error message 0-22 on the fax report
The error message means you have received an fax but there were problems because of poor line condiotions. Ask to resend. Here is lonk to manual.
Ricoh FAX5600L Operator Manual Error Codes
Jan 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Need instruction manual for a Ricoh fax 2050L
Go to the Ricoh site at the following link and under "facsimile", download the Fax 2000L manual, it's virtually identical. I don't know why they don't have the Fax 2050 version, as it is slightly more recent model, but anyway, this should work for you:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
please rate me :)
Jun 17, 2009 | Ricoh 2050L Laser Fax
Ricoh 2050l confirmation reports
It's more complicated than it needs to be. You'll have to refer to the user manual under 'user parameters'. It's to difficult to explain here. But I can tell you that it is switch '3'......Bit '0' that needs to be changed. manual is here if you need it:
* select "Fax 2000L" from the drop down menu (it's the same as yours"
*please rate me :)
Mar 13, 2009 | Ricoh FAX2210L Plain Paper Laser
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
242 people viewed this question
k24674
jasbo
jasbo
