Question about Master 1500ID Combination Padlock
I just bought a master lock 630d and the shackle got stuck in the 90 degree position where you can set your own combination. I had already set the combination, but now nothing is working to release it from this position. Is there anything I can do??
I have a Master combination lock alphathat i can not lock. the slot at the bottom to change it can not be turned either
The slot will only turn when the lock is on the right combination and the shackle is open. The shackle will not lock if it is not on the right combination. I have not seen one, but if it is open and you can see the tumblers move around inside the shackle hole, you should be able to move the top ring until you can see a big slot or gap, then move the next ring down until you see the slot in that one, etc, until you have all the slots lined up. That will be the right combo, and you should be able to turn the coin slot and set it to a new combination.
Sep 29, 2017 | Locks & Locksmithing
I forgotten my skybag number lock how to open the lock .
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Feb 05, 2015 | Master Lock TSA Set your Combination Lock...
Master lock 647d
Look at the combination you just set and, if necessary, write it down.
Return the shackle to the 90 degree position and pull up/out on the shackle. Here are the full instructions:
http://www.masterlock.com/pdfs/646_647_instructions.pdf
Aug 16, 2014 | Locks & Locksmithing
Presto combination lock
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
Reset combination abus 160/50
The answer can be found at http://www.lockwiki.com/index.php/ABUS_160: "The shackle can only be opened when the correct code is dialed and this is required in order to reset the code. With the correct code dialed in the user pulls out the shackle, turns the key on the right-hand side of the lock 90 degrees clockwise and sets the new code on the dials. The new code is in effect once the key is turned back to the vertical position."
Dec 09, 2012 | Locks & Locksmithing
I just bopught a master lock 1590d and theres no password to unlock it for the first time plz help
  • Set your own combination using 3-letters or numbers or a mix of both
  • Combination easy to change with included reset tool
  • Maximum security with anti-shim feature
  • Hardened steel shackle for increased bolt cutter protection
  • High precision dial clicks for fast accurate dialing
Aug 16, 2011 | Master Lock 1590D Set-Your-Own Combination...
I got the master lock speed dial and forgot my combination
Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
Sep 16, 2009 | Master Lock 5400d: Portable Select Access...
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Master 1500ID Combination Padlock Logo
1,499 people viewed this question
Top Master Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
