Question about Armitron Watches
I need to reset the time and can't figure it out
No instructions came with my Studio Time Watch
I have/had the same problem....just found this pdf file that shows exactly how to do it and it worked!!!!!!!!!! Not sure if you already returned it or not....
Nov 01, 2012 | Watches
Cant set time and date on Le Roc sport watch
Took me a while to figure out but this is how I did it Scroll through with mode button until you are at the Time Hold reset button it will start to flash,release Hit start button to toggle between 12/24h clock once you have picked that Mode button again to get year to flash Start button to change Repeat with mode then start buttons until satisfied then Press reset button to go back to normal mode
Apr 30, 2012 | Watches
I have an athletic works stopwatch. All it says on the front is chronograph. I bought it at Walmart. It has 3 buttons on the top and one on the bottom. I can't find the directions. I can't get it to...
I have the same Athletic Works stopwatch. I just figured out how to turn off the alarm: press either of the two mode buttons (middle top, or bottom right) until you see the regular time displayed (the seconds will be changing, but nothing else, and nothing will be flashing). Press and hold the reset button (top left); while holding down the reset button, press the start/stop button (top right). Watch the bell icon on the display in the upper right corner; with each press of the start/stop button you will see the bell either appear or disappear. When the bell disappears, release the reset button. The alarm is now off.
Apr 14, 2010 | Watches
Lost the manual. Son reset watch. I've reset the
go to www.casio.co.uk go to support(methinks??) click on watches and put in the model number (the one you posted) and download the PDF manual relating to your watch (you will need adobe reader free download to read PDFs), this will be the full manual, once you figure it out DST will have to be on, as its summertime of course. ( i bought a wave ceptor for a fiver because the guy who had it didnt know how to recalibrate it after a battery change), a quick gander at the online manual put it right, there shouldnt be a problem setting it up again, good luck
Aug 05, 2009 | Casio Wave Ceptor Watch WVA510A
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
Dec 19, 2008 | Nike Triax Fly WK0006 009 Watch
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
Vestal G5 Global Traveler watch
THE REAL SOLUTION:
1. Hold down (light/el/set--the top right button) for 2 seconds to enter real time setting mode. 2. Press Mode key (bottom left button) to skip around to the different setting items. 3. Press Reset (top left button) to lower a setting. 4. Press ST/SP (bottom right button) to advance a setting (like increasing the time). 5. The day of the week will show automatically if you were correct in setting the year, month, date, and local city.
Apr 19, 2008 | Watches
Need to reset Ultrak 510 soccer watch
To set time and date:
Press and hold upper left button
Upper right resets seconds
Lower left changes item you wish to reset
Upper right moves number to next higher
cycle through using lower left
when finished push on upper left
In timer mode to reset timer:
use upper right to reset minutes
In alarm mode press and hold upper left
press upper left when finished
upper right toggles alarm on or off
Feb 12, 2008 | Watches
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Watches Logo
19 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Bill Boyd
Are you an Armitron Watch Expert? Answer questions, earn points and help others
