Question about GE Dishwashers
Why wont my dishwasher drain. It is not clogged whatsoever. please help.
    Problem Solver:
  • 8 Answers
If the drains lines are not clogged, check the dishwasher drain connection to the garbage disposal. If you have a new garbage disposal, remove the plug between the dishwasher drain line and the connection to the new disposal. Otherwise, check to see if it is clogged at the air gap device at the sink located to the side of the faucet. If there is standing water in the air gap device, water is unable to get to drain.
Posted on Mar 27, 2011
    Problem Solver:
  • 10 Answers
What brand is it and, what is the model number.
Posted on Mar 24, 2011
  • Michael Crockett
    Michael Crockett Mar 24, 2011
    You might need a new drain silinode or drian pump. Depends on the model.
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Have new Hotoint dishwasher that wont drain. Drain not clogged !?
Hi
If the water doesn't drain from your dishwasher, check these: Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain line/air gap Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as "FixYa" if found useful and revert for further assitance.
Thanks
Rylee
Posted on Apr 05, 2009
  • 4088 Answers
SOURCE: DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Posted on Nov 21, 2009
My dishwasher wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
Dishwasher wont drain!
Hi
Daniel
Aug 22, 2011 | Kenmore Dishwashers
Wont drain
Hi
Daniel
Aug 01, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
Wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Apr 17, 2011 | Whirlpool GU2800XTVS Builtin Dishwasher
Water wont drain
Hi
Daniel
Mar 18, 2011 | Dishwashers
It wont drain
Hi
Feb 20, 2011 | Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Wont pump out water
Hi
Daniel
Feb 09, 2011 | Kenmore Dishwashers
Water wont drain from dishwasher
Hi
Daniel
Jan 01, 2011 | Dishwashers
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
161 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
