Question about Epson TM-U295 Matrix Printer
I have epson TM U295 printe. I m install the printer driver but it show in printer and faxes option the printer not available
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
Tm-T88X is not supported by the Windows Vista 64-bit OS
Posted on Aug 24, 2008
SOURCE: Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
Posted on Sep 10, 2008
SOURCE: Epson Stylus Photo R800 (Manual Feed) missing option
I found this answer on Apple.com support discussions.  Worked for me.  There is more information available on the discussion, but this was enough to fix my problem. Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
Matt
Posted on Jan 14, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
Epson TM-U295 Matrix Printer light printing problems The paper i use is 3 sheets, 1 original and 2 copies, the copies no longer print clear, i have tried changing the ribbon but this only improves the...
You need to adjust the print head spacing. This is a lever along the side inside the printer by the print head. It just move the head closer or further away from the paper. The closer it is the harder it strikes the bottom pages and it should print darker on them. If you get it too close it can catch the paper and cause a jam so you have to give it a bit more space. You may end up redoing this if you use a different brand or type of nc form paper. Just open the cover look for a lever on the side and lick it a notch (should show circles so go to the smaller one) and try printing. You might have to waster a few pages before it behaves but this is all you need to do.
Sep 02, 2011 | Epson TM-U295 Matrix Printer
Epson TMU-295 prints in condensed mode with Windows 7 from web application while the same printer prints the same output in normal mode with Windows XP. How comes?
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
Aug 11, 2011 | Epson TM-U295 Matrix Printer
I am unable to print with the printer TM-T88 III. the status of this printer is 'Not Available'. OS is Xp , and i install the driver APD_412.e. Please advice, george
Your printer is probably set to Off Line. You'll need to go to Start-Printers and Faxes, and in the new window right-click the Epson TM-T88III icon and from the popup menu select the Use Printer Online setting.
If this doesnt work check to see if the USB cable is loose both at the PC end and at the printer end. While you're at it, see if the printer shows any signs of life (any lights on, any messages on the LCD)? There just may be an issue of loose power cable, so you may want to check that also.
Jan 14, 2011 | Epson TM-T88III Thermal Printer
EPSON TM-T88iii printer 'Not Available'
I've had this issue many times. The only resolution is to completely uninstall the printer using the epson utility then re-install. This solution is only temporary as it will go to unavailable within 2 or 3 days.
Apr 09, 2009 | Epson TM-T88III Thermal Printer
Tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Feb 18, 2009 | Epson TM-U295 Matrix Printer
Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Dec 03, 2008 | Office Equipment & Supplies
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Installer Problem
please go the www.driverguide.com
and install the driver
Mar 28, 2008 | Epson TM-U295 Matrix Printer
EPSON TM T88IV THERMAL PRINTER
how is the printer connected? usb, parallel, network, etc?
Nov 01, 2007 | Epson TM-T88III Thermal Printer
Epson TM-U295 Matrix Printer Logo
1,140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
