Question about Hitachi 50DX01B 50" Rear Projection Television
When I turn on the tv it comes on but with blue & red shadows around the picture. After awhile it clears up
  • 158 Answers
Your lamp for the rear projection needs to heat up, you may need to replace a part inside and may need the help of a service technician for parts identification and replacement as well.
Posted on Mar 24, 2011
Tv come on but cant clear the picture from turning red and black how can I get a clear picture?
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
Jan 02, 2015 | Televison & Video
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Our 1991 RCA P52150CP rear projection TV has gradually been getting bright cloudy blue, slight haze around letters & shapes-(especially blue channel change headings) when first turned on and then it...
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run you about 300 to 500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red and blue shadows on my sony wega
hello it sound like convergance chips might be the trouble
shaun
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Jan 21, 2008 | Philips 55PW9363 55" Rear Projection...
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Blue screen
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Hitachi 50DX01B 50" Rear Projection Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
