My one year old Day and Night heater is throwing a diagnostic code 6 -- flashing 6 times, meaning it doesn't sense the gas(?). Gas is on. Can I reset this myself?
  • 8,220 Answers
How could it sense gas? What it probably means is it does not sense gas ignition. These new fangled furnaces rely on electronic ignition. The only probo is a built in safety system which verify s ignition has occurred. This is critical. The system must confirm their is flame from monitoring resistance in a flame sensing probe and that verifies Houston we have ignition!. Ok what I believe might be happening with your furnace is the sensor is contaminated with a buildup o it which won't readily allow enough noticeable change in resistance for the control to recognize if the gas is lit. We would not want raw gas going into the house would we? So I would remove the flame sensor and clean the residue off it and retry like in this video
Posted on Mar 24, 2011
Testimonial: "Great tip. Worked like a charm. Thank you so much!"
    Sergeant:
    Novelist:
  • 185 Answers
Shut the power off to the furnace, and try cleaning the flame sensor with a brillo pad or wire brush and then restart the furnace. The flame sensor looks like a probe..... it will have a wire running to it and have a white porcelain shaft with a steel rod in the center attached to the burner with the probe in the path of the flame. opposite the ignitor on the burner section. Normal operation is that the ignitor lites the flame and then the gas valve opens and if it doesn't prove flame by the flame sensor it will shut it self off and then retry again and if it fails to prove flame then it will go into lock out and flash a error code.... If you reset power to the furnace it will try and lite the furnace again....
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,check to make sure the power is off...
IF YOU ARE NOT ALREADY SURE YOU CAN DO THIS JOB
SAFELY AND COMPETENTLY
REFER THIS WORK TO QUALIFIED PROFESSIONALS
  • 1 more comment
  • Anonymous Jul 11, 2011
    www.sdf.sdf
    www.sdf.sdf
    www.hhjkl.jkl
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
The whirlpool water heater does not light bright enough to lite the pilot lite for the burner
Check the gas control valve and also the thermocouple. Be very careful of a back flash it will burn your hands, arms and face if they are to close.
Good luck,
Marty
Good luck,
Marty
Jan 13, 2013 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
FV sense code
Type of gas control valve is not known.
Brand of water heater is not known.
FV event can mean that air intake is clogged, gas control valve has gone bad, or FV system has tripped, or TCO has tripped ... or all of above.
Clean air intake, download manual from manufacturer and read troubleshoot section, call manufacturer.
Copy following links for troubleshoot resources
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Jul 16, 2012 | Whirlpool 6th Sense 40-Gallon 12-Year Gas...
My Haywood H250FDP heater fires up for a few seconds and goes out. After several tries I get a Low gas pressure/No gas error code. I had my propane suppier come out and check. He tried to adjust the...
the flame sensor/thermo couple can be bad and or needs cleaning --carbon build up [one day old -one year old- 20 yrs old defective or damaged parts can happen any time]
Jul 04, 2011 | Hayward H-series Electronic Gas Pool...
I have a york diamond 90 diagnostic 1 flash lock
open the top of your unit so that you can see into the burner box
what your looking for should be an orange wire that leeads up to a metal rod
that metal rod should be in the way of the flame when unit is on
this is your flame ground,,, or more commonly known as the flame sensor,,, take this out and goive it a good brush with some steel wool
and reassemble,,
this should clear up you problem
Nov 04, 2009 | Goodman GMS90703BXA Heater
Pilot lights but heater does notstart burning it sounds like everythings starting up its about 15 years old worked fine then one night smelled some gas shut it off next day would not work its propane
its most likely dirt/rust in your burner assy , but as its 15 year old and propane do your self a favour and get it inspected by a registered gas/propane engineer .
ive witnessed propane explosions at first hand and they are scary
Oct 23, 2009 | Dayton Gas Fired Heater LP TC200VA - Heats...
Code 11 01 - Hot Water Heater Kicks Off
if you have build up in the heat exchanger it will cause the unit to use more gas to heat your water, if the gas line isn't sized properly then your going to kick the error codes off. it sounds like you have two problems, first you have build up in your heat exchanger and it needs to be flushed and second you need to get a bigger gas line to it
Aug 19, 2009 | Water Heaters
My day&night heater just started to blow air and no heat,
Count the flashes on the circuit board. Check the diagnostic codes listed on the inside of the doors next to the wiring schematic. This code should narrow down the problem. The most common problem on a gas furnace would be either a dirty flame sensor or a bad hot surface ignitor.
Apr 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
