Question about Lexmark X4690 Wireless InkJet Printer
When I print the status bar says ink ?? the cartrages are full and i am unsure why it will print an allignment but nothing else
    Genius:
  • 1,087 Answers
Make sure the Lexmark services are running. Refer to this article in the Lexmark website: How to Check and Enable Services Utilized for Printer Communication with Inkjet Printers. Also found in the same window is the Print Spooler, make sure the service is running. Then try to print again.
If you need additional assistance, don't hesitate to contact Lexmark technical support.
Posted on Mar 24, 2011
Allignment page will not print correctly
Print heads alignment completes after scanning fully printed align page. In this case all colors are not printing due to cartridges faulty.. You need to replace both cartridges at a time to this types of errors..
Jan 05, 2013 | HP PSC 750 All-In-One InkJet Printer
Loaded new ink cartridges. Levels read full. Made 6 Nozzles checks. Levels showed practically empty. Paid $75 for 6 checks?
if it isnt putting out any ink and seems like it should work. then 90% of the time it means its just fine. no matter how many times you check it. youd know if you made all the ink leak out. if your unsure then id say compare weight against an old ink cartrage of the same type. there will be a diffrence. also if its not printing correctly it means that you just need to run a good 30 to 50 papers through with just that ink color and clean the hell out of the ink cartriges like 5 to ten times and wait till that color ink starts showing up. i just had to do this with a black ink cartriage.
Sep 20, 2012 | Epson WorkForce 545 All-in-One Printer
How can i check which ink are out
Your printer should have come with a disk. This disk would have installed the necessary program that runs printing jobs, as well as keeps track of the ink level. Locate this program on your computer (may be under All Programs, Accessories under the Start Menu).
If not, Go into the Control Panel: (see below)
Above, you see "Hardware and Sound"; and below that shows "View Devices and Printers. Click on this. It will then bring you into the below dialogue box, of which shows any and all printers currently installed and which are being used. (see below)
Once you have located your printer here - (name etc). Go into your Start Menu: In the Search Box at the bottom type "programs"; look for the words "show which programs are installed on your computer", should be the fourth in the list. Below is what the list will look like. Find your printer here to ensure it's installed.
Once you have determined it's installed, you need to locate the printer program in your file system. Once you retrieve this, click it to open it. The program should allow you to view the ink levels. With most printers, when ink is low it will automatically open a dialogue box showing the ink levels for each cartridge. If you're printer is not equipped with this feature, then the only way to know if any need changed is when printing a document, and any color is not present.
I apologize for such a long response, as I wanted you to know how to access these files. If you are printing, and all colors appear to be present, without fading, or "blotchy" spots, then your cartridges are still good. You should be able to do a print test (calibration or alignment test) to determine this as well.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 27, 2011 | HP Officejet 6500 Wireless All-in-One...
Will not print on paper
if the cartridges were out of the printer for any length of time the ink has dried up on the print heads. you most likely will have to replace the ink cartridges. then allign again before it will print correctly
Apr 04, 2010 | Lexmark JetPrinter Z22 Color InkJet
I have just tried installing a Deskjet F4280. Igot to the stage where the printer should print an allignment page but it didnt.I returned to the beginning and restarted but got the same result.what have I...
by pass the allignment for now then take out the ink cartrage and install it again and it should go to the allignmnet after recongnizing the ink as new cartrage hope that help
Sep 11, 2009 | HP DeskJet F4280 All In One Printer InkJet
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
WONT COME OUT OF THE ALIGN CARTRAGE MODE
if the colour cartridge is empty or any of the three colour is not got printed on the allighnment page it will not comple allignment.replace the colour also or get you colour cartridge refilled.
May 06, 2009 | HP PSC 750 All-In-One InkJet Printer
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Lexmark X4690 Wireless InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
