What will be the possible prob with wincor passbook printer showing carrier error at screen?
5 Suggested Answers
SOURCE: Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Posted on Jan 17, 2009
SOURCE: Have 2 IBM 9068-A01 Dot Matrix Passbook Printer.
The cover is not shut all the way or the magnet is not making the connection between the cover and the chassis. A1 is a microcode checksum error. don't know what that means.
Posted on Mar 03, 2011
  • 1746 Answers
SOURCE: Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Posted on Jun 24, 2011
vaishnav_bal
SOURCE: passbook wincor 4915 xe
transport error
Posted on Dec 19, 2013
Wincor nixdorf 4915xe, i get "carrier error" on display, occasionally. what is this error pointing at?
Carrier error relates to ribbon. If ribbon is very loose or not properly installed it will give carrier error. Reseat the ribbon assembly and tighten the ribbon using knob available on top side.
Oct 14, 2014 | Office Equipment & Supplies
Wincor highprint 4915xe carrier error
Can you help me?
Error code 0x8204
Machine wincor nixdorf highprint 4915xe
Oct 04, 2013 | Office Equipment & Supplies
Epson PLQ-20 is not power on. Then how to power on printer?
printer power problem no powering on (epson plq20 printer supply show digram and layout of both side please send me
Dec 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
A PLQ20 passbook printer is not accepting passbook or another paper
Hi, here are two possible solution, kindly follow me and resolve your problem.
You mean that you load paper into the printer tray, but it doesn't pull it into the print, though it's acting like it should, and you get an error on the printer, then most likely your paper pickup/feed from rollers, it may possible that the problem is dusting or worn out. You can try to clean them with a cloth and water or alcohol, otherwise they may need to be replaced.
If your printer just doesn't see that it has paper and gives you a paper out error, then you may have a sensor problem in the printer, or the printer is expecting a different paper size or paper from a different input than what is loaded (depends on the printer), then you may have a programming issue.
I assure you that your problem will resolve easily.
Good Luck
Feb 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
How to calibrate epson PLQ 20 PASSbook Printer
How to calibrate epson PLQ 20 PASSbook PrHow to calibrate epson PLQ 20 PASSbook Printerinter
Jan 25, 2010 | Epson Passbook PLQ-20 Matrix Printer
115 people viewed this question
k24674
jasbo
jasbo
