Question about GE Profile PDW8480JSS Built-in Dishwasher
Water is coming from the bottom - GE Profile PDW8480JSS Built-in Dishwasher
    Problem Solver:
  • 10 Answers
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Posted on Mar 24, 2011
Leaking water on floor appears to be coming out of fridge at bottom inside. after removing vegi crisper cannnot see whereits coming from suggestions please
does it have a water line, if so make sure that is not leaking. check bottom of freezer to make no standing ice or water is on the bottom.
Nov 29, 2015 | Refrigerators
Water is coming out of the bottom of my Quick and hot instant hot water heater, whats wrong
Water coming out the bottom is usually an indication that the tank has failed.
Jan 30, 2015 | Water Water Heaters
Have a new electric tank,top element wont come on,replaced thermostat 3 times top element comes on once but next morning not enough hot water&top element wont come on,can someone help? thanks
The top element only comes on when the heater is about out of water. The water is directed to the bottom of the tank. Cold water stays on bottom, Bottom heater element heats water. If you use all that water then the top of the tank gets cold and the top element comes. When the top of the tank is warm, then the bottom element comes on. I would susupect the bottom element as it does most of the work. If you have an ohm meter, turn off electric, and remove wires from element. Check element for continuity. If you don't get reading, then that element is bad.
Oct 04, 2010 | General Electric Water Heaters
I don't know how to open the shower. It only works the water below
Hello. At the bottom (spout) where the water comes out it have a pull button. Just pull it up and water should comes out trough the shower head. If water comes out without pressure and is partially comes from the bottom just replace the spout. (bottom part)
Aug 30, 2010 | Delta T13420 Chrome Classic Single Handle...
Keurig b40
We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 17, 2010 | Keurig Elite B40 Coffee Maker
Water on the bottom inside the Freezer
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
Mar 18, 2010 | Frigidaire Model: PHSC39EHSS
How to flush the anti-freeze in1997 gran marquis
remove bottom and top caps from radiator, turn car on, place water hose in radiator, turn water on slow, let run for a while, making sure water is constantly coming out of the bottom of the radiator. keep an eye on hose to ensure water is not coming out too fast and that the hose does not come out of the radiator. watch color of water at the bottom, wait till it is totally clear before taking the hose out and shutting off the car. make sure you turn car off the allow all the water to come out. replace bottom cap, then fill with 50/50 fluid to proper level and fill side container to proper level as well
Jun 24, 2009 | 1997 Mercury Grand Marquis
Heating elements do not operate together
That's how they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank
Mar 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
GE Profile PDW8480JSS Built-in Dishwasher Logo
115 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
