Question about Whirlpool Refrigerators
Inside light went out...replacing bulb did not work, any help or advise? thanks! Mike
  • 31 Answers
Many times when the inside light fails to operate...it could be:
(1) A bad bulb ...replace with a known good one.
(2) Bad connection of the light bulb in its socket.
(Remove the bulb and spray the socket with WD-40 Spray Lubricant) then...
(3) Replace the bulb with a known good bulb..use a dry rag to securely tighten the bulb in its socket.
(4) The "Door Switch" could be bad. Replace bad "Door Switch" with new one.
Hopes this helps....Good Luck! ...... HandyHenry
Posted on Mar 24, 2011
  • lmnc512
    lmnc512 Dec 31, 2012
    Sprayed socket with WD-40 and it totally worked! Thanks so much!
Turn signal don't work on right side. does not come on inside or out
If the light on dash is on but not blinking then you have a blown front or rear bulb.
Turn on you flasher and walk around car and check all the light for bad ones
replace bulb
Hope this helps Mike
Feb 15, 2016 | 2001 Dodge Durango
1994 camaro - right turn signal and brake light went out - replaced the bulbs - worked for about 30 minutes and went back out - now the dash board lights went out.
when bulb went out what color was the inside of the bulb the reson I ask sometimes moister in the bulb will burn it out if it is clear you have a differnt Problem if its milky white it moister
Sep 28, 2010 | Chevrolet Camaro Cars & Trucks
Dome lights won't come on
Check it very careful use a test bulb to verify the fuse connection, sometimes visual checking alone is not enough.
Jun 01, 2009 | 2000 Hyundai Elantra
Breeze's brake light went out. changed bulb, now whole tail light won't work.
sounds like you put the wrong bulb in, that will make it blink fast. re check
Apr 18, 2009 | Plymouth Breeze Cars & Trucks
Car headlights. I have replaced the two dipped headlight bulbs as the old bulbs stopped working. They are now very dim when on dipped, and are only as bright as the side lights. The Full beams are...
It's actually VERY unlikely for BOTH bulbs to go at the same time - sounds like you have a wiring problem (loose connector somewhere or wire trapped and abraided ...) ....
See if you can follow the wires from the light clusters across the engine compartment (will be after the two sets 'join up' since both bulbs are effected) .. if you can't find an obvious break / connectror, you will have to take it to a garage ..
(If only one light went & you changed both, did you fit the right 'wattage' bulbs ??)
Nov 18, 2008 | Peugeot 405 Cars & Trucks
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
GE Refrigerator
If you have heating in the freshfood side there is only one possible. The light inside is staying on and allowing the bulb to heat up the refrigerator. To fix this you will need to replaced the door switch. To check simply unscrew the light bulbs and see if the problem goes away, or open the door and push on the door switch and see if the light is going off. Please let me know if this is not the problem and I will be happy to help. Please let me know if this did FixYa.
Mike
Sep 07, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Light bulb replacement in a Tappan Microwave
Hi Mike.
Difficult to say on yours. You may try the following. On the back or side, if there is a little cover that's screwed into the panel. Otherwise browse around on the inside. Be sure to unplug the micro before checking. Once found be sure to replace with a microwave lamp and not a fridge lamp. There is a difference. Good Luck,JUS004
Feb 28, 2008 | Microwave Ovens
Refrigerators Logo
271 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
