Question about MTX Thunder® TC8001 Car Amp
No output light on top of amp lit, also light by speaker output lit.
    Problem Solver:
  • 6 Answers
Sounds like something internal as long as you have a good ground and power but remember that there is a remote power too, that is supose to hook up in the back of stereo so there are two power lines that are for the positive side of amp and one ground
Posted on Mar 24, 2011
Testimonial: "good and quick answer"
  • Greg Adams
    Greg Adams Mar 24, 2011
    can you explain the operation of the 2 lits
  • Joseph Minkin
    Joseph Minkin Mar 24, 2011
    if there is two lights one usualy is power and the other is overload or protect which means it was over powered or hookedup wrong
Samson 65a: power good, speakers good , LEDs lit, no sound at all?
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 11, 2016 | Samson Resolv 65a Main / Stereo Speaker
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
One channel thermal overload stays lit and no output from that channel. even after unit sits overnight, thermal light on immediately,unit not hot. Looking for schematic?
Red light is on if:
- thermal protection, overheated amp, bad thermo sensor
- DC at speaker terminals
- high current at output transistors
Also could be a protection circuit malfunction.
In any case you need new channel module or send your module or whole amp for repair here.
Thanks,
Paul
Jul 12, 2011 | Adcom GFA-7607 7-Channel Amplifier
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
POWER SURGE
sounds like DC on that output.
needs service possibly fried all the output transistors on that channel
Jul 30, 2008 | Xantech PA1235X Amplifier
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
No sound
did you set your gains and base boost also when you put sterio back in dash did you put rca's on proper outputs or the rca's could have pulled out when putting back in
you have high output and low output
are your subs getting sound to them at all any current going threw speaker wires to subs
radio settings might not be set to back end for subs this is a feature on most receivers to shut off back end subs
May 08, 2008 | Kicker KX200.4 Car Audio Amplifier
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
MTX Thunder® TC8001 Car Amp Logo
93 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
