Question about Compaq Computers & Internet
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ?? Thanks
  • 112 Answers
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Posted on Mar 24, 2011
  • owenbrittont Mar 24, 2011
    Does not recognize either usb mouse... arrow keys aren't it. Using Windows XP Pro Apparently this Compaq Presario 2200 has it's own language
  • Jeremy Mar 24, 2011
    That's odd. Do you know if the keyboard still works?
Keyboard and touch pad stopped working
check the drivers file. and system file it may be corrupted. go to my devices check keyboard setting. and do same for mouse setting. use an external mouse to do this usb or cable.
Jan 14, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
My laptop touch pad not working so i want to touch cable\
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 29, 2012 | HP Compaq Presario 2200 Notebook
Hi, I have a Compaq Presario CQ56 & the scroll area on my mouse pad isn't working. Can this area be turned off and if so, is there a way to turn it back on/unlock it?
The scroll pad on the touch pad needs a particular driver Synaptics Pointing Device Driver. This will actually run at the startup after installed which will activate the functionality of scroll on the touch pad. You can also actually turn this function on and off so this is a friendly user.
If you do not have that driver that comes with your laptop you can go here:
http://www.compaq.com/cpq-country/cpq_support.html
or here
http://www.synaptics.com/support/drivers
Good day.
Jun 19, 2011 | Compaq Presario CQ56-115DX Laptop
HP Compaq Presario CQ60-249US PC Notebook, my trackpad and mouse buttons have stopped responding. I am trying to check the cable connections and possible install a new one. Anyone tell me how to remove...
To access the mouse cable remove the battery - remove the screws securing the keyboard - carefully lift the keyboard out and check the security of the cable BUT in your instance look at the small on / off button in front of the mouse pad and ensure it is turned on ( blue light ) for on yellow off -- if it is blue go to Started - all programs - recovery manager - activate recovery manager - select advanced options - select reinstall a selected driver - select the touch pad driver - reinstall - reboot if that fails go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3872064#N1238 & download & install the latest touch pad driver. If still no go your up for a new top cover assy
498410-001 Chassis top cover assembly - With touchpad (Presario)
Also it maybe the on / off cct board assy that failed
502907-001 Touchpad on/off circuit board
Jul 06, 2010 | HP Compaq Presario CQ60-249US Notebook
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
Compaq presario V3105TU touch pad not sensitive
Try goign into the touch pad settings and tunring the sensitivity way up. either by its software or goto the control panel and mouse settings. hope this helps in some way.
Dec 03, 2009 | Compaq Presario Notebook
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Scroll sections on mousepad not working
almost certainly this means that the drivers for the touchpad have reverted to the windows generic drivers. Try the driver from Compaq here. Sadly, without knowing the OS and exact model number of the laptop I can't be more specific on the link than that. The exact model of the laptop is usually printed on a sticker on the bottom.
Nov 29, 2008 | Compaq (153515-001) Touch Pad
Mouse pad not functioning
if u want to reinstall drivers For presario 1200 please use below link for drivers
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=96065&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
in this link please select correct model no witch u have & Opoerating system .then download Synaptic driver for u r touch pad
If this Link useful for u please Rate me ......
It is Helpful for my Rating avg.
Jun 28, 2008 | Compaq Presario 1200 Notebook
Computers & Internet Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
