Question about Emerson EWC13D4 13 in. TV/DVD Combo
My Emerson TV-DVD combo powers on and runs a channel search or tries to change settings on its own. It also over-rides signals from the remote. It switchhes modes so that I cannot watch DVDs. Occurrences of the problem are random day and night.. I have tried covering the sensor with aluminum fois and by hanging a CD in front of it. I have changed it's position in the room and the direction it faces three times. Nothing works! It is not connected to any input media, I only use it for watching DVDs.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Emerson Expert
  • 177 Answers
I think problem not from remocon.
Switches on front may cause it.
Open than replace switch may solve this problem.
Posted on Mar 24, 2011
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I have a EWC19T3 tv/vcr/dvd combo my ex-boyfriend threw the remote and shattered it. I have a philips/magnavox universal remote but I've tried all the codes listed for emerson (which is a lot) and none of...
Unfortunately, the remote you picked up may be incompatible with your current TV. (I found older universal remotes didn't work with my newest set that had a digital tuner. These were remotes that worked with ~20 year old tvs (analog only). Similarly a new remote might not work with an older TV. Then you get stuck with the result you have.)
Remotes.com has a substitute remote that has all of the functions of the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWC19T3&uuid=12792355576670
This one will work.
Your TV has Select, volume and channel change buttons on the front of the TV. So a tedious way to deal with the problem is to move to the TV to change channels. The Volume controls are under the DVD tray. Select (toggle TV/VCR, DVD, and external input) is the first one on the left under the VCR cassette slot. The channel up/down is to the right of the Select.
I wish that I could be of more help.
(However, you might try the Philips Remote Code Finder: http://www.urc.philips.com/ and select your country and click on the right arrow. Then find your remote model and see if you can get a single number for your TV. On the newer remotes I looked at, it only returned a code of 0917 for All Emerson devices.)
Jul 14, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 12, 2009 | RCA Universal Remote 3 Device Remote...
Programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Dec 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Remote control
Get a miracle remote for a fraction of the cost of the original...
http://www.miracleremote.com/
Bill
Dec 07, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
then release SET.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
blink twice.
1 through 5, but substitute the appropriate device key for
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
Emerson EWC13D4 13 in. TV/DVD Combo Logo
52 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
