Question about Vacuums
I have read that the Company site for the Living Air XL-15 had a trouble shooting guide. I can not seem to find this site. Can you help?
    Problem Solver:
  • 7 Answers
Try this link for a possible manual:
http://homeappliance.manualsonline.com/
Posted on Mar 24, 2011
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Brush will not turn
brush will not rotate... should I ASSUME it is an upright? IF SO, I assume that it has a drive belt. I guess that you have removed the 3 or 4 screws that hold the belt cover in place and have confirmed that te belt is not broken. Note that excessive hair in the belt drive area can prevent the brush from turning. If you have an air pressure drive system (rare), then hair can clog the air flow to the drive impeller. You provide no information that can guide me to give specific trouble shooting suggestions.....or solutions
Jan 13, 2012 | Vacuums
Hi, I can't get the warning lights to stop flashing on my vacuum.... it had caught a string on my door mat... I removed the string, did all of the trouble shooting that my guide recommended including...
try to reset or find the reset button it means the trouble about the string was on the memory of your vaccum that trigger the flashing of light. try to unplug your unit then after plug it on
Mar 06, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My Oreck XL is shooting dust out from the roller when I try to vacumn
This is a sign that the bag is full or there's a clog in the air flow piping. Check behind the brush for clogs and remove if there is. Open the cloth bag, remove the paper bag, and check inside the tube. If no blockage is visible, drop a coin or marble down the opening and see if it rolls out. If not, there's a clog that needs removed. You can use an air pressure hose to blow it out..
Feb 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
On my M&S Air Vac AV425 central vaccuum system, the system usually turns on by inserting the vaccuum hose into one of the vaccuum outlets. However, it now runs continuously. I am able to turn it off...
we are a central vacuum service company and we service all of new jersey. sounds like you have a short some where that keeps your unit running or it could be your relay module thats stuck our number is 908-721-7595 its j&j central vacuum services
Dec 28, 2010 | Vacuums
I`m looking for a alpine living air XL 15S instruction manual
Hi, I have the air purifier, and on the back of the unit is the number to call to have them send you the manual...it's:
1-800-989-2299
Hope this helps! I couldn't find a PDF one online for you to download it from the site.
Gwen
Aug 24, 2010 | Vacuums
I have a freshield vacum sealer it won't open help please it's new I read the instructions but there's no way I can open without forcing it.Elite FSN .
WE turned it off first,turned it on then repressed the hand push button make sure the lid was shut properly then it popped open.so I started again but made sure that both sides were shut.
Nov 21, 2009 | Vacuums
Dyson DC07
This is an incomplete solution. Mine (DC 14 Animal) worked great and then it didn"t and then it did after checking to make sure that all the parts were on securely. I noticed that while the suction sort of seemed normal, it was not strong enough to pick op fine dust from window sills.
The elbow thing near the floor on the right side was not seated properly. I fixed that and it worked great for a while and then lost too much of suction again for no apparent reason. I took a look on the Dyson web sight and they have a trouble shooting guide. The first step is to inspect the main filter and clean it. If I do this again I'll go through the rest of the check process before I clean the filter with cold water as recommended to avoid waiting (12 hours?) for the filter to dry. Mine did not appear dirty and I was unable to rinse out scads of dirt.
I followed the instructions for clearing airways and checking seals... with the canister removed, all suction seems to be fabulous. I'll know in the morning if it really works again after the filter is dry and I can reassemble the thing.
Short version? Try the troubleshooting guide at Dyson.com. I'll try to add to this if it works like new again! All in all, it seems simpler to maintain and trouble shoot that any other vac I have owned.
Good luck,
Tim
Jan 08, 2008 | Vacuums
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
