Question about Roland PK5A MIDI Controller
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note on the other unit. The question is: can i fix something on the pk-5a or i have to made a special midi box to go in between the two pk-5a to send a midi message like midi off or cancel note or something like that. Thank
  • Roland Master
  • 5,603 Answers
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Posted on Mar 24, 2011
How do I octav shift on the roland kr 3500 keyboard.It has been off for about 6 months.
Contact Roland directly
http://shop.rolandus.com/home/contact/614.0.1.1
Roland USA
5100 S. Eastern Ave.
Los Angeles, CA
90040
US
Phone: 323-890-3700
Fax: 323-721-4875
Jan 20, 2018 | Roland Music
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
Feb 07, 2016 | Yamaha YPT-320 Keyboard
Can you please tell me the best amp that I can use to hook up a Roland SPD 30, I'm looking for one to get volume. ( loud ).
Hi, With my sound engineers hat on I would use a small PA. mixer, amp and speakers!!!!
For quality you need a full, flat frequency range system with good headroom.
I assume this is for your own listening, when using an acoustic kit?
There are one box solutions.
  1. Drum amps. Like a monitor wedge with an amp, Roland do a PM-10, Various other makes are available.
  2. General purpose powered wedge.
  3. Keyboard Amp, these are full range and available in various sizes.
  4. Bass amp with high frequency driver (tweeter), not the best but will have good bottom end.
  5. Powered or active speaker, much like a powered wedge, but a different shape, needs an input volume control.
All these systems need to have large bass units, 10 inch minimum, and will be in mono. Two will give you stereo,
How loud depends primarily on the sensitivity of the speaker. But manufactures insist on selling things by power. Worth looking this up.
At a couple of feet away, 20 watts should do it, with high sensitivity speakers, more likely you find most things as above start at about 70 Watts.
Good luck, I hope I have widened you choices a bit.
All the best, Chris the Fader.
Oct 03, 2014 | Roland Spd-30 Drum Pads
When I hold in C and then press Csharp in the same octave,the C-sharp goes silent.It goes the other way around as well.They work when I tap them separately.And that problem occurs in every octave of the...
It sounds like the piano is in mono setting. One note at a time can be played. Find out how to set it at poly mode, allowing multiple notes to be played at the same time.
Jul 09, 2014 | Yamaha P-155 Electronic Piano
My pedal oc3 does the octav , but it makes not at the same time I play
A very slight delay would be normal as it takes the pedal electronics time to acquire and creae the second harmonic. The ear is sensitive to about 1/1000 second. You haven't said how much delay it is causing... If it is over 1/20 of a second there is a problem.
May 05, 2011 | Roland Boss OC-3 Pedal Octave/Synth
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
Roland fantom g8, problem, The last 2 octaves do not issue sound
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Feb 23, 2011 | Roland FANTOMG8
When I play my Bass Clarinet, the bottom joint won't play the higher octave. It will play everything except the 3rd octave B-E. I can't find any leaks.
usually If a certain note doesnot play the note before it is not seating correctly. Check all pads that they are sealing behind the bad notes, also make sure the octive key is sealing.
Feb 11, 2011 | Yamaha 5C Standard Bb Bass Clarinet...
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Need rubber boot key contacts
Try wdgreenhill.com for the parts. They are in England but give great service and specialize in hard to find parts.
Jul 03, 2009 | Music
Roland PK5A MIDI Controller Logo
216 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
