Question about Samsung Televison & Video
We just replace the lamp in are tv and it was good for 5 hours and blow the lamp why do it do that
    Scholar:
  • 81 Answers
Just asking, did you accidentally touch the bulb with bare hands? if you did the oils from your skin, the ones that leave fingerprints, cause hot spots on the bulb causing it to fail. if you must handle the bulb with bare hands, wipe it off well with rubbing alcohol and let it dry before applying power to the light.
Posted on Mar 24, 2011
Wont' Turn On
You took the first correct step. You really need to take this thing apart again, and blow the darn thing outwith a leaf blower.I had the same problem and then cleaned it out with the leaf blower and it works. The cooling fins or heat sinks are covered with dust and lint, this creates an insulation that needs removed. This will return the cooling property needed to sustain life. When you replace the back cover be sure you have a good ground. The cover when properly closed will complete a good ground,and stay on as well.
May 30, 2013 | Samsung HLR6178W 61" HDTV
We have the Akai 52"
Replace the lamp, after you replace the lamp reset the lamp hour meter good day and best regards.
Aug 28, 2011 | Akai PT5492S 54" Rear Projection...
Every so often ithe screen just goes blank and you can't change channels or input devices when it does this. There are no blinking lights or no codes being shown, the green power indicator light stays...
It sounds lamp is reaching to end of its working life and causing that problem due to its weak result.
Replace lamp in tv to solve this issue. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 01, 2011 | Sony KDF-E502000 50" HDTV
My TV goes off by its self and the power light will blink off and on for about a minute or so and then it will come back on by its self and stay on for 5-10 min and go back out again. Can you tell me what...
It is symptom of dying lamp that has been reached at end of its working hours life, replace lamp in tv to solve this issue.
Lamp replacement procedure is easy and written in user manual. Please buy Sony original lamp for good picture in tv.
Thanks.
Jan 06, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
TV comes on with a good clear picture and about 30 to 40 sec goes off.
The tv projection lamp have not been replaced in this tv like the last 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours a day?Yes,than the tv projection lamp life is over.The tv projection lamp,require replacing.
Oct 18, 2010 | Samsung HL-S5087W DLP TV
I turned on my tv and after about 30seconds is sounded like a light bulb blew and the tv went out. whenif is on now if has a crackling in the back intermitently and when you look in the back grill you can...
The tv projection lamp has not been change in this tv the last 1/1/2 or 2 years and been on an watches 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 05, 2010 | Samsung HCM5525W 55" Rear Projection...
The power lamp flashes when turned on, no picture???
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
May 14, 2010 | Toshiba TP55H60 55" Rear Projection...
Reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDF-60XS955 recycles after a few hours of use
Pull your Lamp out and look to see if looks blowed. More then likely Lamp is Problem / lamps $119.00 Acme Has Them call 1-800-575-9833.
Jan 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture & Sound blink off 45 seconds, blink back on, repeats
If the lamp is foggy then you really need to replace it. The lamp life is typically 5 to 7 thousand hours. However if your tv gets a lot of dust inside which is pretty normal as most people don't vacuum the dust off from the rear cover on a regular basis then the lamp life will be drastically reduced. I suggest you replace the lamp and make sure the inside of the tv gets vacummed out to remove as much dust as possible. A Sony servicer should be able to check the amount of hours on your lamp. You'd be suprised how soon 5-7 thousand hours happens. If the lamp will not come on after replacing it the lamp driver may be at fault. You haven't said how may times it's blinking. If it's 5 then the lamp driver may be at fault.
Sep 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
