Question about Dishwashers
I have a whirlpool quiet partner 2. It seems the whole washer is draining out of the air gap. This has never happened before and as you can imagine, makes a huge mess. The washer fills normally and runs normally, but is draining out the air gap an d all over the floor. Help!
    Problem Solver:
  • 10 Answers
Your air gap connect to the garbage disposal. The hose that makes that connection may be cloged. It is also possible the the plug that is in the disposal was not knock out. Check for a hole inside disposal were the air gap connects. If the plug was not removed. Unplug disposal. Then pull hose off and knock it out from the out side in with a screwdriver. Do not leave that plug in the disposal. Make sure the hose is not kinked when you reconnect it.
Posted on Mar 24, 2011
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I recently replaced the chopper in my whirlpool quiet partner III. now it won't drain. I can push the cancel drain button and hear the pump running, but nothing happens. I tried reversing the wires to...
It sounds like you've done a lot to try and fix your dishwasher. Make sure your air gap is not plugged up and double check the drain hose. If those are clear change out your drain hose. Part#8270145 the elbow connector sometimes have a bad check valve and could keep it from draining.
Hope that helps Thanks please rate me
Dec 11, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Whirlpool drain problem
there is a check valve on the drain that gets cloged with food
take out the drain line and clear the clog
Oct 07, 2008 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
