Question about Whirlpool Refrigerators
The water dispenser on my 'side by side' Whirlpool refrigerator will not shut off. Model: ED5LHAXMB10. We had shut the household water off while away on a trip, upon returning and turning water back on... we found that when dispensing water 'in the door' dispenser... it will not shut off and just keeps pouring out. We have hard water, so i don't know if a lime deposit build up is the problem or perphaps an electrical switch problem inside of the water dispesner in the door. i have replaced the water filter and problem persist. The fridge is approx. 6 years old, but dispenser gets very little use.
  • Charlie305 Mar 24, 2011
    Thanks, still wondering though....
    It seems to work intermittently, sometimes staying on and sometimes not. It is dripping water for a period of time, even after I press the 'lock dispenser' button. I wondered if having the household water turned off and draining down the line a bit has some thing to do with the problem... along with hardwater issue...?
    -Charlie305
  • 29 Answers
This could be caused by a malfunctioning fill valve. Here is the one it calls for. Valve is in back, it is what water supply line connects to.
Posted on Mar 24, 2011
    Gabe1:
    Thanks for the solution. It seems to work intermittently now...dripping water slowly for awhile. I have it in 'locked dispenser' mode now.
    However, I still wonder about the fact that we had no problems until turning and draining household water while away at spring break. Hardwater issues, air in line...? versus electronic switch malfunction...?
    Is there any way for a layman to diagnosis without buy/replacing new valve mechanism on the back of fridge?
    We hardly ever use the ice maker... should I dare turn the ice maker on... or am I asking for more water overflow issues to add to my hardwood floors...!??
    Thanks,
  • gabe_t
    gabe_t Mar 24, 2011
    You probably have some deposits in the valve. Your symptoms are normal for a valve going bad, the only thing to do is replace it.
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I need to clean the plastic parts in the ice and water section on the door of the side by side Model ed25cq
Use mild household cleaners. If you have a brown build up use vinegar to clean. Soak if needed. Good luck. Please rate so I know if I helped. Thanks.
Dec 30, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Dec 01, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
External water dispenser on Whirlpool Conquest model GS6SHAXKS01
Try this first. In the inlet side( where the little water line comes in) there is a small screen where the water is hooked up. Shut off the water and unhook the water line. there should be a small screen to keep out particles from entering your ice make/ water dispenser. See if that screen is plugged. If so clean the screen. you can put it in vinager over night if you want. It will help clean it.
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
463 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
