Question about Pentair 3/4hp 115/230v Booster Pump - La01n
I have a Pentair 3/4HP booster pump LA01N also. It just started making a grinding sound. I do work with industrial pumps and I am trying to fix it. My confusion is it only makes the sound under load. I can run the motor with no impeller and push on the shaft with no noise, I added the impeller and no noise, I added the volute and no noise, I added the suction line and pumpe water no noise, I connected the discharge line and then there is noise. I can blow in the discharge line and no retriction ples no cleaner connected at the time.. Pump is a few years old. I inspected the impeller and finger screen and both are clear. thanks
  • stevekcodysr
    stevekcodysr Aug 22, 2012
    How do i fix a noisy pentair booster pump?
SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
Posted on Jun 26, 2009
SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
Posted on Jun 28, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
  • 990 Answers
SOURCE: my pentair whisperflo is making a load squealing
When you have noise in the pump it is usually a rumbel or rattel. If you have a squealing it is probally in your motor and is more than likly a bad bearing. If you have any water leaking at your seal this is probally the problem and it will just get worse. Sorry to say you are very close to a new motor.
Posted on Dec 07, 2009
  • 13 Answers
SOURCE: Hi, My booster pump for my pool is very loud. It
changing the seal is ok but if the shaft has become corroded then you will not get a true seal. the noise is most probably the bearings and replacing them doesn't always help.
best solution is to replace the whole pump which will give you years of use instead of months
Adam
Canadian Spa Company
Posted on Oct 04, 2010
Why Pentair booster pump LA01N not working?
Need more info. Check power and all switches. Is it connected to any automation?
Jul 22, 2017 | Pentair Pool & Spa
Why does my Pentair Booster LA01N sound as if it is spraying water internally ?
I think it's got air in it - that's what cavitation sounds like. Is the pickup gathering some air? Do you have an air bleeder near it someplace, or a valve you can use to bleed air out of it?
Jul 15, 2014 | Pentair LA01N Universal Booster Pump, 3/4...
How to remove the impeller of pentair booster pump?
Remove the rear motor cover, you will need pliers and a 7/16 open end wrench. The opposite end of the impeller has a shaft that has to be secured by the wrench. The shaft has a notch on each side, it could be behind the two small springs that hold the spinning connection. There is a bigger shaft version that needs just a small end cap taken off and that will expose the shaft to be held and that is a bigger wrench. Once the shaft is secured, you may need pliers to turn off the impeller. Turn counter clockwise. Remember to be careful, it's plastic and well used. Don't forget the seals to put it back together.
Feb 09, 2013 | Pentair 3/4hp 115/230v Booster Pump -...
Wiring instructions to rewire Pentair universal booster pump from 240V(Factory wired) to 120V.
see side of motor for schematic for low voltage you have to move wires or change a switch
Jul 05, 2011 | Pentair 34 HP Pool Pressure Side Booster...
Motor won't start, gets hot
Check the pump for an obstruction... the bearing that they are not seized up and the motor that it turns freely...other then that the motor is no good...
heatman101
Jan 05, 2011 | Pentair 3/4hp 115/230v Booster Pump -...
Motor will not start,
Thank you for posting your question here on Fixya.com.
Does it make any noise as if it is trying to start? If so it could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If not you will need to examine the power coming into the motor and look for trouble there.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
Dec 24, 2010 | Pentair 34 HP Pool Pressure Side Booster...
Pump did not trun on happen yesterday
could have blown a fuse on the circuit board, air lock in pipework or pump may have failed.
Adam
Sep 12, 2010 | Pentair 3/4hp 115/230v Booster Pump -...
Hi, My booster pump for my pool is very loud. It is a Pentair model number LA01n. It has gotten louder over a period of about 2-3 months. It has a small leak in the front seal and I had the seal...
YOUR BEST BET IS TO COMPARE MOTOR REPLACEMENT TO AN ENTIRE PUMP REPLACEMENT
MORE THAT LIKELY ITS PROBABLY NOT A GREAT INVESTMENT TO JUST DO A MOTOR ON A BOOSTER PUMP
YOUR MOTOR IS NOISE IS COMING FROM BEARINGS INSIDE THAT ARE GETTING WORSE AND WORSE
NOW A DAYS I STRONGLY DON'T RECOMMEND EVEN TRYING TO REPLACE JUST BEARINGS THEY NEVER LAST LONG AND ITS ALMOST AS COSTLY
HOPE THIS HELPS--CHARLIE -POOL PROS
Sep 04, 2010 | Pentair 3/4hp 115/230v Booster Pump -...
Pump is not drive enough water to move the sweeper
If the pump ran dry at all and if you had air it very well may have you could have burnt the impeller or it may just be clogged, Remove the 6 bolts holding it together and pull apart, using pliers or vice grips hold the shaft and unscrew the impeller if it looks ok run a curved wire through the veins of the impeller. This should help. If the impeller is clogged their is something getting past the filter and you will need to fix that. Also. don't forget to check your finger screen.
May 13, 2009 | Pentair 3/4hp 115/230v Booster Pump -...
Pentair 3/4hp 115/230v Booster Pump - La01n Logo
186 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
David Spradling
David Spradling
Are you a Pentair Garden Expert? Answer questions, earn points and help others
