Question about Samsung RS2630WW Side by Side Refrigerator
Hi ! my 3 years old fridge Samsung Rs2630ww
Hi ! my 3 years old fridge Samsung Rs2630ww recently stop working only one light on front panel "freezer" is flashing. We replaced rear control board, front control board, transformer beside rear control board but nothing changed. WE had 3 different technishians from different companies but they all dissapered . Problem still exist . PLEASE HELP WITH ADVISE WHAT IS PROBLEM?
    Sergeant:
  • 194 Answers
Lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Posted on Mar 24, 2011
The middle bar on my side by side refrigirator is very hot!
hi,i want to tell you i don't work on samsung fridges,they just don't give techs any info,you have to work with samsung to get any info but on any other fridge if the strip is hot or really warm either the condenser coil on the bottom is clogged with dust or the condenser fan isn't running to cool off the compressor and blow the hot air across the condenser coil,so remove the bottom front kick panel and see if the coil is clogged,they have had alot of problems with the computer board to so if the board is bad the fan might not be blowing fast enough to cool it down but check it to see if the fan is blowing,pull the fridge out,remove the bottom panel and check the fan,i've seen other machines do this,and the fan has to be ordered,if you get a house fan and blow it on the back where the compressor is it should help cool it down so you don't cook your compressor and you won't loose any food until you get it fixed.i hope this helps you out and good luck,call whoever you bought it from or call samsung and they will send a certified tech there to help you out or go here to look up parts,if it is the fan motor you can replace it if you want to give it a shot.go here put your model number in and look up parts
https://www.searspartsdirect.com/model/search.html?q=lt608
Feb 04, 2018 | Samsung RS2630WW Side by Side Refrigerator
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
The center of the fridge between the freezer and fridge is so hot you cant touch it whats wrong should I call a repair person ? thank you for any help
HI, this is a sign the fridge isn't cooling proper. Check and see if there is frost building up on the rear panel of the freezer. Check and see if the evaporator or the condensor fan motors are running. Check and see if the compressor is running.
Pleasae let me know if I can assist you fyrther.
Vic
May 21, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Mar 08, 2008 | Samsung RS2630WW Side by Side Refrigerator
Fridge and Freezer do not keep foods cool
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
Aug 01, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Jan 13, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
177 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
